What Gear or Should I Care? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > What Gear or Should I Care?
The Original 3/8" Ruffstuff Diff Cover!3" BDS Suspension Lift Kit - Jeep JK 07-11Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-25-2015, 04:08 PM   #1
bakerla
2003 FSJ Cherokee
My old 2003 JGC was a five speed with the Overdrive. When towing my boat I could press a button and lock out the Overdrive to save the tranny from shifting all the time, risking burnout.
I recently bought a 2015 JGC Limited with an 8 speed transmission - with paddle shifters for those so inclined. I am content to leave the Jeep on Automatic. But I am concerned about what I should do, if anything, when towing my 16 foot boat once a year to Minnesota. The trip is mostly Interstate. With the stuff we throw in the boat, I am probably pulling 2000 lbs. Don't want to jeopardize the tranny.
bakerla is offline   Reply With Quote Quick reply to this message
Unread 08-25-2015, 05:17 PM   #2
Kev M
2012 WK
2000 # lol.
I used to tow my > 2000# 16' Silverline SS with a Subaru Forester, a Subaru Baja (both with NA 2.5L 4 cyl motors) or with my Jeep Cherokee (XJ) with 4.0L and never once thought I needed to worry about the transmission (well, maybe with the Forester in the Poconos).
Anyway, with that light a load behind our V6 WK2 I'm not sure I would even know it was back there.
If you're not climbing the Rockies I don't think it matters and even then I'm not sure it would.
Kev M is offline   Reply With Quote Quick reply to this message
Unread 08-25-2015, 05:57 PM   #3
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I would follow the owners manual:
"The DRIVE range can be selected when towing. The transmission controls include a drive strategy to avoid frequent shifting when towing. However, if frequent shifting does occur while in DRIVE, you can use the Paddle Shift switches to manually select a lower gear.
NOTE: Using a lower gear while operating the vehicle under heavy loading conditions, will improve performance and extend transmission life by reducing excessive shifting and heat buildup. This action will also provide better engine braking."
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now   Reply With Quote Quick reply to this message
Unread 08-25-2015, 06:53 PM   #4
Ah673000
Originally Posted by bakerla
My old 2003 JGC was a five speed with the Overdrive. When towing my boat I could press a button and lock out the Overdrive to save the tranny from shifting all the time, risking burnout. I recently bought a 2015 JGC Limited with an 8 speed transmission - with paddle shifters for those so inclined. I am content to leave the Jeep on Automatic. But I am concerned about what I should do, if anything, when towing my 16 foot boat once a year to Minnesota. The trip is mostly Interstate. With the stuff we throw in the boat, I am probably pulling 2000 lbs. Don't want to jeopardize the tranny.
No worry.....D and go.
Pull my 1000 MC on a small trailer a couple 1000 mile trips per year..... V6 8 speed doesn't even know it's back there.
Ah673000 is online now   Reply With Quote Quick reply to this message
Unread 08-27-2015, 09:33 AM   #5
caulk04
2008 WK
Here's the thing with towing/hauling anything: If the trans picks a gear and isn't hunting, leave it alone. When it starts hunting, lock in in the lower of the two. Done.
08 5.7 Limited WK - Basic stuff...
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 08-27-2015, 01:50 PM   #6
gabbagabba
2014 WK
Use sport mode and it will use a lower gear at all times
gabbagabba is offline   Reply With Quote Quick reply to this message
Unread 08-27-2015, 08:37 PM   #7
llahtjp
you can also monitor the transmission temperature in the EVIC menu.... and select appropriate gear.
llahtjp is offline   Reply With Quote Quick reply to this message
