Well, she can tow. - Page 2 - JeepForum.com
post #16 of 21 Old 03-06-2012, 07:42 PM
Heath
2014 JK Wrangler
Originally Posted by Big50
Yep, it's Sac. Mine is still streetable as well. I just tow it as I hate having to swap tires at the track and if something brakes. There was a 335i out this weekend and he broke. Luckily for him it was only a half shaft.
That day 11.2. Best to date is an 11.01. I'll get into the 10's sooner or later. It's a stick so it definitely makes things more difficult for drag racing. At 604 whp I would probably running 10.7's with an auto. It's only pushing 15lbs of boost. I plan to do a cam swap soon and crank it up to 20lbs. The blower is good to 25-28lbs. Just have to save up some coin.
Hemi
LOL
Thanks man. I have the kb 2.8 on mine. I would have gone whipple but for some damn reason they refuse to come out with the 2.9 for the 3V
I made 595 HP with a crappy Saleen blower BBR heads and BBR cams with the stock short block. 14lbs in my 05 GT. we backed off the boost and made 500 HP for longevity reasons. Plus at idle that Saleen blower sounded like it was crushing rocks inside it.
2013 JKU Rubicon
Heath is offline
post #17 of 21 Old 03-07-2012, 07:42 AM
JeepOrvis97
JeepOrvis97's Avatar
Ya, they tow nice....
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #18 of 21 Old 03-07-2012, 10:09 AM
2MchFun
2016 JK Wrangler
Originally Posted by l8tapex View Post
But the other is the bad boy. 6.0 built low compression T76 turbo in the 2,700. lbs RX7R1.
Now when 700 HP isnt fast enough then I have issues.
An LS2 in an RX7 - woohoo, that's gotta be a handful!
I've seen a few of those around - sweet car!
JKUR - Bone stock (for now).
2MchFun is offline
post #19 of 21 Old 03-07-2012, 10:09 AM
Hookem_Overland
2011 WK
This is actually quite impressive
2011 Grand Cherokee Overland--4X2--5.7
Hookem_Overland is offline
post #20 of 21 Old 03-07-2012, 10:23 AM
Syndicate
2012 WK
I'll have to meet you out there some day. My 335 is pushing low 11's (11.3 @ 127 is my best) and will hopefully be in the 10's once I get my new 3.5 bar TMAP sensor so I can run more than 22 psi. I broke a half shaft a long time ago as they are our week links, had to find a beefy one to replace it with. Getting an aftermarket LSD also helped that issue.
*edit - they 335 who broke down actually broke his axel. He's running close to 700 rwhp on a modified single turbo car. He just posted a video of it on the e90 forums.
2012 Jeep Grand Cherokee Overland - 5.7L V8, QTII, Off-Road Aventure II - Max Steel/Blk
2010 Mercedes ML350 - Blk/Blk
2008 BMW 335i e90 - Alpineweiss/Blk
Syndicate is offline
post #21 of 21 Old 03-07-2012, 06:50 PM
l8tapex
2012 WK
Sorry OT :
So if you go with the 3.5 bar will you have to recalibrate your program so it can read it accurately?
I know when I did mine( in the hi boost rotary motor app) I had to use a vacuum pump to mark the reading on the pump and what the 3 bar sensor was reading. We then had to make the math adjustment so the ecu would read the boost in calibrated form.Stock ECU would read only 17lbs.
Or is this a map sensor from the BMW line?
________________________
2012Overland 4 X 4 Deep Cherry Red Crystal Pearl Coat, SRT8 Hood and Spoiler
l8tapex is offline
