water drain - JeepForum.com
post #1 of 5 Old 06-03-2016, 01:13 PM Thread Starter
jerseyjeep1175
water drain
I just wanted to say hello to everyone in the forum community and I have a question that seems to be familiar with jeeps.
ok it is not my AC from the start nor my windshield or sunroof. Last Friday I took a short cut to avoid a traffic jam and ended up getting my GC stuck in puddle of mud that was about 2 1/2 ft deep the entire was submerged , everything seems to be working fine radio, engine, transmission, which I have changed the oil, and transmission fluids already luckly it looks like there was not water in the oil or transmission as best as I can tell. my problem is whenever I come to a stop I hear the water between my floorboard and undercarriage, I found the drain plug on the passenger side of the jeep but I can not find it on the drivers side any help would be great.
Thank you
Tim
Tim Yamanaka
2012 Grand Cherokee Laredo
Tuckahoe, nj
jerseyjeep1175 is offline
post #2 of 5 Old 06-03-2016, 04:17 PM
Jake03KJ
2007 WK
You don't happen to have water in the battery compartment or the same compartment on the driver's side?
Don't forget to check the well where the spare is stored.
14 WK2 Summit EcoDiesel/ Nokian WRG3 tires
Lost to the Ex. 07 WK Overland CRD Black/4xGuard Belly Skid & Rear Skid/Amsoil/Custom Winter Front/InMotion Stg II/MBRP Exhaust
Jake03KJ is offline
post #3 of 5 Old 06-03-2016, 11:00 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
You may also want to check/change the dif and transfercase fluids.
There were a few posts awhile ago about water sloshing, I'll try yo find them when I get back to a computer.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #4 of 5 Old 06-04-2016, 12:52 AM Thread Starter
jerseyjeep1175
@ColdCase , and Jake03KJ,
I'll have to check Saturday to see If that may be where it is at, I know that it is on the drivers side for sure the drain plug on the passengers side I've left out just in case any water may go onto that side. But do you know of any drain plugs on the drivers side of the 2012 GC ? Just wondering. I'll look in the battery compartment and spare tire area tomorrow. thanks guys I'll let you know what I find.
Tim Yamanaka
Tuckahoe, nj
post #5 of 5 Old 06-04-2016, 02:40 PM
AtomicJoe
2014 WK
FWIW I had a particularly industrious squirrel get an acorn or some kind of seed stuck in the longitudinal support under my hood. It's the long boxed in brace between the fender and the engine compartment. Every time I would stop or go I would hear this damn acorn rolllllling. For the longest time I thought it was stuck between the floorboard or in one of the channels under the floor because I could actually feel it under my feet. I ended up squirting some spray foam into the support under the hood, and while it was still sticky took a drive. Heard it roll once and then never again.
My point with all of this is the water could be trapped in there and still sound like its in the underside of your jeep. There seems to be no provisioning for any draining from that support. It's only open on one end.
AtomicJoe is offline
