Vibration Shudder heard in the cabin. - JeepForum.com
post #1 of 14 Old 01-04-2013, 04:59 AM Thread Starter
imaz
2012 WK
Hi,
My 2012 JGC is only 3 weeks old, September build. Today it has developed a vibration shudder when idled. I can hear and feel it is coming from the engine compartment, heard for a good 2 seconds and comes and goes.. It does not make any different to the RPM, or with A/C on or off. Drive is normal.
Anyone else have this problem? v6 Petrol.
2012 Jeep Grand Cherokee Limited 3.6L v6, Mineral Grey.
2009 Ford Falcon XR6 4.0L Inline 6, Octane Orange.
Down Under - Perth, Western Australia
imaz is offline
post #2 of 14 Old 01-30-2013, 08:38 PM
Rjhamp
I have the same vehicle & same annoying problem. Does anyone know what it is????
Rjhamp is offline
post #3 of 14 Old 01-30-2013, 10:34 PM
2cobras
My 2013 does the same thing, but I have the V8 Hemi. I only have 2000 miles
2cobras is offline
post #4 of 14 Old 01-30-2013, 10:44 PM
shekshishekki
2013 WK
That's HEMI GROWLING!!!
shekshishekki is offline
post #5 of 14 Old 01-30-2013, 11:58 PM
Dave2002ti
2012 WK
Maybe
The rear driveshaft is failing
Dave2002ti is offline
post #6 of 14 Old 01-31-2013, 06:46 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I think the V6 has an electric power steering pump. That and the ABS pump are about the only things not run off the engine. I'm not sure if a loose steering shaft would have this kind of symptom.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #7 of 14 Old 01-31-2013, 07:28 AM
Dave2002ti
2012 WK
Have the dealer check
The rear driveshaft. Not sure where they fail or its a assembly line issue but this maybe the problem. It will get worse if its the driveshaft and you ahve problem putting any power down on even a slight incline.
Rear driveshafts are in short supply. My original date of shipment for the aprt was in March.
post #8 of 14 Old 01-31-2013, 05:01 PM
2cobras
I don't think its the drive shaft. It only happens when parked, idling. Not when its in drive.
2cobras is offline
post #9 of 14 Old 01-31-2013, 06:14 PM
altitude474
My 2012 altitude seems to be doing the same thing. It does not do it consistently. I first noticed it while in park, then noticed it again while in drive stuck I. Traffic about a week later. Does anyone have any info on this problem? Or just speculation?
altitude474 is offline
post #10 of 14 Old 02-06-2013, 09:57 AM Thread Starter
imaz
2012 WK
Sorry for the late reply.
I called the dealer and they said they can take a look. I haven't bothered taking it in as when I did bother, the thing didn't make a sound... I still get it and tried recording it, but with my luck the sound does not get picked up with my voice recorder device... One of those things if you can't prove to the dealers then it ain't broken...
Most on the forums claim it is the AC compressor, and if you press the dealers about it, they will replace it. I'm hoping that's all and nothing related to the cylinder head. Mine also happens when Im driving, but less noticeable. The sound is like an AC compressor piping vibration into the cabin, rather than anything relating to the power stealing and definitely unlikely the drive shaft.
imaz is offline
post #11 of 14 Old 02-17-2013, 09:53 PM Thread Starter
imaz
2012 WK
Just got back from the dealers. I walked in and told them to check the tvx and compressor. They found the A/C was low on gas, so they refilled it to the correct weight. They claim low gas can cause piping vibration to the tvx. Car is 8 weeks old and even from factory low on gas can be common.
Touch wood all is good, will report back in a week or so if the problem persist. So far on the drive to work from the dealer was all good. My A/C is also noticeably cooler...
imaz is offline
post #12 of 14 Old 02-18-2013, 01:47 AM Thread Starter
imaz
2012 WK
I spoke too soon, on the way home from the office, the noise returned, faintly though. Immediately booked it in again for the 5th March.
imaz is offline
post #13 of 14 Old 07-22-2013, 05:27 PM
Saltriverfolk
2013 WK
2013 WK AC Piping Vibration
What was the final fix for this? Imaz, my 2013 WK is doing the same thing. I held the cold side pipe with the hood open at idle with AC on and the piping is vibrating every 5+/- minutes when the compressor engages. Motor normal operating temperature and about 90 degrees outside temperature. You can hear the noise in the cabin.
Saltriverfolk is offline
post #14 of 14 Old 10-01-2013, 04:23 PM
txguy67
This sound is happening more often now on my 13...WTF!!!! Of course the dealer states "could not duplicate". I hear it right after the compressor engages.
txguy67 is offline
