unfixable problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > unfixable problem
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 06-14-2012, 11:02 AM   #1
moonysue2000
unfixable problem
I have had a moaning/groaning sound coming from the front end of my 2011 Jeep Grand Cherokee. When I brought it to the attention of my service person and returned to pick the car up I was told there was no fix for the issue but that Jeep engineering was working on it. Apparently I am not the only one experiencing this issue. The noise occurs when I am going slow, but not with the brakes applied. When is stop and go traffic the noise escalates louder and louder and sounds awful. I contacted Jeep customer assist but that was utterly useless as no assistance was offered other than if I wanted to get out of the car she would send my case to the legal department. My service person called 2 days ago to say Jeep had said there is still no fix but could be the result of some bolts not being adequately fastened and to get to those bolts my entire transmission would have to be removed. Needless to say I am highly aggravated and disappointed with the whole situation.
moonysue2000 is offline   Reply With Quote
Unread 06-14-2012, 11:05 AM   #2
smcutter
ex-n00b
smcutter's Avatar
Wait... so they offered to let you out of the car? As in, a full refund?
How many miles do you have on it? I know it may be a hassle, but it may be a pretty good deal if they are so willingly allowing you to get out of your Grand Cherokee. If they're willing to let you do a straight swap for a similarly outfitted 2012, that may not be a bad idea.
2012 Rubicon (Black, Soft Top, Heated Seats, 6spd)
Rugged Ridge XHD Front Bumper and a Warn PowerPlant HP Winch
Next up: ACE Rock Sliders, EVO MFG ProTek Skid System
More of a Tinkering Thread than a Build Thread (smcutter)
Colorado Jeep Club Member #302
Keep Calm and Chive On!
And for the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline   Reply With Quote
Unread 06-14-2012, 11:06 AM   #3
smcutter
ex-n00b
smcutter's Avatar
(also, this thread should be moved elsewhere)
Unread 06-14-2012, 12:15 PM   #4
Jackal01
Car ram rod
Jackal01's Avatar
2012 WK
What's wrong with them dropping the tranny to try and fix the problem? It is still under warranty so it is not like you are out anything except time and your GC. Kinda of a pain but this is what a warranty and insurance is for. If they are actually letting you out of your current GC for a new one, I would jump on that.
'12 Laredo V6 ORA1|Terra Grappler 265-70-17|MB TKO 17x8.5 0 offset|Silverstar lows|Mopar Front and Rear WK2 slush Mats|RRO 2.5" lift
BWoody extended sway bar links|K&N 77 Series Intake|Gibson Exhaust
Jackal01 is offline   Reply With Quote
Unread 06-15-2012, 11:33 PM   #5
RB145
2011 WK
He did not say they are buying him out of it. He said they would pass it on to that dept. The customer service person has no power to really do anything except listen to the complaint. As far as the repair they are talking about, there is a tsb for loose bolts on the flex plate I believe it was. So the trans and torque converter would need to be removed. This was for a rattling sound. It sounds like your dealer doesn't have a clue and I also would be wary of this repair. In my opinion once they are taken apart like that they are never the same.
RB145 is offline   Reply With Quote
Unread 06-19-2012, 06:52 PM   #6
efrench515
Jeep Forum Supporter
efrench515's Avatar
2012 WK
I had a very similar problem. Whenever I would take off at low speed there was this awful grinding sound. It was embarrassing when trying to park. I took it to the dealer and they admitted they could hear the sound but they had no idea what could be causing it. They made me an appointment to bring my GC back in the next Tuesday and they said they would start taking the front end apart until they found they issue.
It wound up being a nice weekend so I decided to get underneath and take a look for myself. Well the cause was simply a rock stuck between the skid plate and the transfer case near where the drivers side half shaft comes into the trans-axle. I was able to pop out the rock with a flat tip screw driver and once again all is quiet
2012 Grand Cherokee Laredo X 4x4 ORAP2, Mineral Grey/Black Leather
2011 Buick Lucerne CXL Premium, Cyber Grey/Tan Leather
efrench515 is offline   Reply With Quote
