Under the hood? - JeepForum.com
post #1 of 8 Old 03-06-2012, 06:26 AM Thread Starter
grand767
Under the hood?
Just picked up our new 2012 Overland with the 6. Popped the hood to show a friend the engine and noticed on the hood lip there is a rubber "seal" along the driver's side but missing on the passenger side. Does anyone know if this is normal? I assume it is and has to do with the air intake on the driver's side. Much appreciate the help on this.
grand767 is offline
post #2 of 8 Old 03-06-2012, 06:30 AM
BMRisko
2012 WK
It is the "snow blocker" for the air intake...perfectly normal.
BMRisko is offline
post #3 of 8 Old 03-06-2012, 06:34 AM Thread Starter
grand767
That's what I figured, but just to confirm you are talking about the seal that is attached to the underside of the hood, right? Not the "dam" on the top surface of the grill?
grand767 is offline
post #4 of 8 Old 03-06-2012, 07:16 AM
steveinaz
2011 WK
It's only on 1 side (air intake side). I took my jeep back for the same thing, the mechanic showed me 6 other cherokees, same thing.
2011 Grand Cherokee Laredo 4X4
3.6L V-6 with Selec-Terrain
Off-Road Adventure package
Tow package
steveinaz is offline
post #5 of 8 Old 03-06-2012, 03:07 PM Thread Starter
grand767
Thanks very much!
grand767 is offline
post #6 of 8 Old 03-07-2012, 01:15 PM
padgett
2012 WK
Found the seal, is right at the edge of the hood and looks like it is sealing air/rain from flowing over the top of the headlight.
Seems odd: the seal is across the edge of the headlight and it appears to want to pull intake air from the slots on top of the grille and over the radiator support cover to the intake. This makes sense however there is a foam barrier strip that will block most of the flow (see picture). The path in the grille, out slots on top, and around to the intake should keep rain/snow/birds out of the intake but the barrier makes little sense other than to block the air flow. Wonder why (sell CAIs ?)
Need to monitor the Intake Air Temp using my OBD scanner with the barrier in place and with it removed. Might be interesting.
One of these is a diesel.
We take in orphans. Notary Sojac y'all.
padgett is offline
post #7 of 8 Old 03-07-2012, 03:01 PM
txwest
2012 WK
As mentioned a few posts above, it blocks things from blowing into the box. Snow, dirt, etc etc.
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline
post #8 of 8 Old 03-07-2012, 03:47 PM
WvTaco
2011 WK
i have the rubber seal but not the foam barrier.
the temps from my scangaue 2 are about 3-5 deg over outside temps. same with my 07 camry se i had that had an intake that looked almost the same as the jeep .
WvTaco is offline
What kind of material is the hood made of? magr80 WK2 Grand Cherokee Forum 17 01-28-2013 06:29 PM
Hood bug deflector redjeep11 WK2 Grand Cherokee Forum 20 10-08-2011 09:44 PM
Under the Hood Lighting MOD - Super Bright LED waterproof strips grimper WK2 Grand Cherokee Forum 1 05-16-2011 12:24 PM
Plastic Hood Porkgrisle WK2 Grand Cherokee Forum 7 03-26-2011 11:49 AM
