Uconnect and iPhone iOS8 thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Uconnect and iPhone iOS8 thread
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Alloy usa heavy duty ball joint kitsENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 09-18-2014, 11:50 AM   #1
otherwisebusy
Anyone brave enough to try the iPhone iOS 8 with UConnect in their WK2 and care to report on what does and does not work?
I know I had issues getting text messages to show up on iOS 7.1.2 but finally figured it out.
I figured as often as updates to either platform it may be worth having a common thread to discuss any current and future updates.
2014 GC Limited, Off road adventure II, quadra drive, quadralift, luxury, NAV. UJC#141
otherwisebusy is offline   Reply With Quote Quick reply to this message
Unread 09-18-2014, 01:12 PM   #2
adamchrtrnd
2015 WK
I was able to have my text messages show up just fine with iOS 8 when I went to lunch today. Still can't send text messages like other platforms so the functionality is still the same from the previous iOS.
2015 Jeep Grand Cherokee Altitude 4x4 3.6L V6 - Bright White
adamchrtrnd is offline   Reply With Quote Quick reply to this message
Unread 09-18-2014, 01:14 PM   #3
Noko
2014 WK
I see no difference than iOS 7, music still plays through Bluetooth and I am able to access my contacts via voice commands. Text messages still come up on the display, but sadly you still can not create them through the uConnect voice commands.
Noko is offline   Reply With Quote Quick reply to this message
Unread 09-18-2014, 02:32 PM   #4
EvanP
I upgraded to iOS8 and am having problems playing music and podcasts when the iphone is connected via usb cable. I can navigate through the menus and select various items, but the selected item usually does not play and when it does I cannot scrub backward or forward through the track.
EvanP is offline   Reply With Quote Quick reply to this message
Unread 09-19-2014, 09:44 AM   #5
kc_jeep
But now you can easily reply by just saying "hey Siri" and not have to touch your phone if it is plugged into a power source
kc_jeep is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 08:31 AM   #6
adamchrtrnd
2015 WK
That is a good point. I will have to try this the next time I am in the Jeep.
Unread 09-23-2014, 09:15 AM   #7
SVTour
2014 WK
My wife complained about an issue since upgrading to iOS8 that she did not see with iOS7 - basically, when playing music through the USB, the UConnect system would toggle back and forth between Sirius Radio and the USB. She said it was happening every 20 minutes or so on a 3 hour drive.
I've never experienced anything like this with my Samsung...
SVTour is online now   Reply With Quote Quick reply to this message
Unread 09-23-2014, 09:26 AM   #8
mx71
2013 WK
Excuse my ignorance, but why do so many people use USB for music and not bluetooth?
mx71 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 10:38 AM   #9
tubbyzj
1990 XJ Cherokee
Everything works on my 13 overland
Only annoying issue is all my sounds that my phone makes either text email or Pop ups
Makes the radio play its sound that the phone makes
The screen on my radio goes into phone call mode an plays that sound for what ever feather, before it never did it
Been trying to figure out how to disable that getting very annoying
Anyone having the same issue or know if it's a phone feature I have to disable or in the radio I have to adjust ?
Its an 87
tubbyzj is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 11:09 AM   #10
bobafettt
2014 WK
Superior bandwidth
bobafettt is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 01:02 PM   #11
Wavicle
2011 WK
Does Not Work
I have an (older) 2011 Grand Cherokee Overland with the RER system and it worked perfectly for hands-free calling with iOS 6 and iOS 7 (no music), but after upgrading to iOS 8 it does not work. There is a connection on both the RER in-dash unit and iPhone 5s, but no audio is routed. Callers can't hear you and you can't hear them even though it makes the calls using voice dial or manual call on the iPhone.
Wavicle is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 01:22 PM   #12
jonpurcell
I have the same problem... Upgraded to iPhone 6/iOS 8, music works fine, phone pairs fine, but when I make or receive a call, it won't play via bluetooth.
jonpurcell is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 07:59 PM   #13
JPcpa
Just bought a '14 Ram with Uconnect. My app for starting and locking no longer will open since I upgraded from IOS 7 and then got an IPhone 6 a Today. Called connect help (and Melissa was quite nice) and was told the app needs to be updated.
2004 LJ, Auto, Zone 3.5"/1.25"BL/MML/285 KM2s
2005 Rubicon, RE 4.5/3.5" SF, 285 KM2s sold
99 Sport, BB, BL, MML, 33s, sold
JPcpa is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 10:41 AM   #14
pheen
2014 WK
I have iOS 8 on my iPhone 5 and no issues with the uConnect app or bluetooth connection to the 8.4A. I haven't tried USB because I always just use bluetooth.
pheen is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 11:38 AM   #15
ryandevans
2012 WK
I had the same issues with my uconnect and iphone 6 (ios8) I just "reset network settings" and everything is back to working with uconnect. You will have to redo the wifi passwords once you do this tho.
hth
ryandevans is offline   Reply With Quote Quick reply to this message
