turbo noise? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > turbo noise?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Axles at CCORRough Country Lift Kits and Parts!
Unread 04-23-2015, 12:38 PM   #1
kryogen
2011 WK
turbo noise?
I have started to nitice lately that my v8 has been making a turbo (high speed turbine) noise at higher rpm..... I guess it's not good, what could be causing this?
2011 Grand Cherokee Overland V8
kryogen is offline   Reply With Quote Quick reply to this message
Unread 04-23-2015, 12:41 PM   #2
tylersheppeard
just about every v8 I know does that. That sound is the engine sucking in air. Higher RPM=More Air intake for combustion.
Whoever said, "if it ain't broke, don't fix it", obviously never had a Jeep.
tylersheppeard is offline   Reply With Quote Quick reply to this message
Unread 04-23-2015, 12:43 PM   #3
tylersheppeard
to assure yourself, take the air box off so you can see the throttle body. start the engine, then open the throttle with your hand. even in my 4cyl the sound of it sucking in air is loud.
Unread 04-23-2015, 12:56 PM   #4
hemispin
2014 WK
Like this??
http://www.youtube.com/watch?v=JZD-ADArwXo
hemispin is offline   Reply With Quote Quick reply to this message
Unread 04-23-2015, 01:02 PM   #5
tylersheppeard
Originally Posted by hemispin
nah, I think it sounds a little more like this
YouTube (Short URL)
?start=" frameborder="0" allowfullscreen>
if it's either one of these then it's only fo' decorashun man, just fo' decorashun
Unread 04-23-2015, 01:19 PM   #6
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Some valve trains will make a bit of noise. Did you change the oil recently, or change brands.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
