transmission when cold - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > transmission when cold
Savvy/Currie Aluminum Control ArmsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAlloy usa heavy duty ball joint kits
Unread 10-20-2014, 09:44 AM   #1
acidsnow
2014 WK
in my 2014 limited, is it normal to have a hard shift between 1-2 gear first thing in the morning when its cold out? after I drive for 5 min its fine after that . . . ?
acidsnow is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 11:33 AM   #2
2kg4u
2014 WK
I had the same thing happen with my 2014 V6 Overland last winter. Almost like it was revving in neutral for a brief moment between 1st and 2nd gear, and would go away after 5 minutes or so. I had the transmission control module flashed for the updates a week and a half ago, but it is not cold enough to see if the problem has gone away or not. Do you have the V6? Have you taken in it for TSB 21-007-13 re-flash of the TCM? Here is a link to the bulletin:
http://www.wk2jeeps.com/tsb/Tsb_wk2_2100713c.pdf
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 06:05 PM   #3
acidsnow
2014 WK
I have the v6, if you are in windsor I'm in kitchener, so we got the same temps . . . and it happened today in the morning and after noon. If you didn't feel it today I would assume its gone for you . . .
I'm kinda skeptical about getting the TCM updated because it is shifting well otherwise . . . I'm only saying this because I had a 2014 Cherokee Trailhawk that I went and updated the trans software and it was never quite right after that . . .
Unread 10-20-2014, 09:09 PM   #4
46er
2014 WK
I had it this morning, temp was mid 30's. Did not have it happen with temps in the 40's. Not something I would bring it in for.
2014 Grand Cherokee Limited, BD 3-14, MDH 031503, V6, QTII, nav, sun roof, fold flat pass seat
46er is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 08:47 AM   #5
acidsnow
2014 WK
Did you have any of the TSB's done?
Unread 10-21-2014, 09:29 AM   #6
14summithemi
2014 WK
Welcome but please search this topic (an participate in those threads) as it has been thoroughly discussed here.
You have company (and some possible fixes) for your issues within those threads.
14summithemi is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 10:53 AM   #7
2kg4u
2014 WK
Before I got the TCM updated I would routinely turn ECO mode off every time I got in the vehicle. Now that the TCM has been updated the shift patterns in ECO mode are much more acceptable, and I have been leaving it in ECO. Despite your experience with the Cherokee I would get the update if I were you.
Roy
Unread 10-21-2014, 11:30 AM   #8
acidsnow
2014 WK
thank you for your suggestion, I attempted a search and didn't find the information I required, if you could be so kind could you point me in the right direction? thank you
Unread 10-21-2014, 11:42 AM   #9
acidsnow
2014 WK
more searching turned up 21-007-13 REV. C can anybody confirm this is a good update? is this all I should suggest to the dealer?
Unread 10-21-2014, 11:51 AM   #10
14summithemi
2014 WK
Service advisers hate to be handed a TSB. It is most effective if state your symptoms, which should match the TSB, and then let them figure it out.
Here is a good start on forum member discussion on this:
http://www.jeepforum.com/forum/f309/...ilure-1566831/
Unread 10-21-2014, 12:34 PM   #11
46er
2014 WK
None at all, although I do not know what was done in prep for delivery. My dealer is very thorough, but I doubt they would put a TSB on without any reason to. I will wait till the cold settles in and see if it is an issue for me, right now it isn't.
Unread 10-21-2014, 02:52 PM   #12
acidsnow
2014 WK
The dealers in this area are VERY bad a diagnosing issues, if I don't blatantly point it out it will be over looked every single time.
Unread 10-21-2014, 03:10 PM   #13
14summithemi
2014 WK
Gotcha. I'm lucky with a pretty good dealer and an excellent service mgr. Good luck.
Unread 10-21-2014, 03:48 PM   #14
2kg4u
2014 WK
That is the correct update. I brought a copy of the service bulletin, handed it to the service writer at the dealer, and told her I had drive-ability issues in ECO mode and a hard 1-2 shift when cold. She thanked me and they did the flash. I see no issues with bringing TSB's with you to the dealer.
Roy
