Transmission Shudder - Page 2 - JeepForum.com
post #16 of 176 Old 02-13-2012, 11:02 AM
ckehl2
2012 WK
Thank you for the update. I have 1400 miles on my 5.7 Overland, and "fishbite" as this tech calls it is a good explanation. Doesn't happen all the time, hard to pinpoint. I have not taken mine in. Waiting to see what is found with yours, then I'll have some idea of what it might be. Keep us posted.
ckehl2 is offline
post #17 of 176 Old 02-13-2012, 11:39 AM
Trailguide
2012 WK
I have a 2012 Hemi and on a certain hill I get the shudder, most likely because it doesn't downshift on the hill. I'm always going 45MPH, posted speed. But I really don't get it like others have explained. On a trip on interstates I don't fell it ever. I guess mine is simply just before where it should downshift. Probably all to do with mileage.
Trailguide is offline
post #18 of 176 Old 02-14-2012, 07:05 AM Thread Starter
hur1ey02
2014 JK Wrangler
You need to take it in NOW. The earlier - the better. Added mileage appears to increase the things that it could be.
Mine happens pretttttttttty much any time its on a hill before downshifting.
Current - 2014 Wrangler Sport; Past- 2011 WK2 Laredo X; 2008 JKU Sahara; 2004 TJ RME
hur1ey02 is offline
post #19 of 176 Old 02-14-2012, 04:36 PM
gator9329
let us know what develops. you are my case study for my dealership trip. I want to go in with all the info I can.
gator9329 is offline
post #20 of 176 Old 02-15-2012, 08:04 AM
GreyGoose
2012 WK
I recently bought a 2012 Grand Cherokee Overland (5.7) and I am also experiencing the same issues. Mine shudders/studders/chokes at @60 Mph on the open highway when I give it some gas, or when going up some slight inclines on the beltway. Drives me crazy - dealer said he has not heard of this problem yet, but it is going the shop on Friday.
Please keep us informed. Thanks.
GreyGoose is offline
post #21 of 176 Old 02-15-2012, 08:34 AM
peckmv
All these dealers keep saying that they never heard of it. I find that hard to believe. Let us know what your dealer finds.
peckmv is offline
post #22 of 176 Old 02-15-2012, 01:20 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
hurley02 -
Were the Chrysler guys there yet?
JeepCares is online now
post #23 of 176 Old 02-15-2012, 02:10 PM Thread Starter
hur1ey02
2014 JK Wrangler
Originally Posted by JeepCares View Post
hurley02 -
I just called to check in on it. She said that they had already looked at it and were using STAR (waiting for a response from Chrysler). We should have an idea as to the next step tomorrow.
If this is taken care of, the next Jeep I purchase will definitely be from Friendship Chrysler Jeep Dodge in Bristol TN. It's amazing at how bad a service department will piss you off and lose the dealership business.
hur1ey02 is offline
post #24 of 176 Old 02-15-2012, 05:55 PM
l8tapex
2012 WK
Hey guys can you all post RPM?
Also have you driven in 3rd, 4rth, 5th, 6th gears and in the same RPM range to see if it happens when trans is locked?
I read some history on the trans on how it uses two gears to make a third. One drum locks on to make the
6th. Something that was complicated but to that affect. Why they didn’t keep the proven 5 speed they are using on the SRT8 and just lower the over drive more. 4rth is one to one on both any way.
Sometimes transmission surge when searching because the load and high gear in too low an RPM. The trans doesn’t kick down (downshifts) when caught in no-mans land.
Just wondering out loud. I’m on heavy cold meds....
________________________
2012Overland 4 X 4 Deep Cherry Red Crystal Pearl Coat, SRT8 Hood and Spoiler
l8tapex is offline
post #25 of 176 Old 02-16-2012, 05:23 AM
peckmv
Chrysler isin't going to do anything about this. Just wait for the aftermarket performance chips to come out. They will change the shift points and this problem will go away. The only downfall wil be gas mileage. Chrysler did this to comply with the governments mileage requirements. Its only going to get worse for people who need the power for towing and hauling. The government thinks that everyone should be in a Prius and we allow it. Rant off......Sorry.
peckmv is offline
post #26 of 176 Old 02-16-2012, 06:10 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
That is so true...
some dealers just don't get it
post #27 of 176 Old 02-16-2012, 08:18 AM Thread Starter
hur1ey02
2014 JK Wrangler
6th. Something that was complicated but to that affect. Why they didnít keep the proven 5 speed they are using on the SRT8 and just lower the over drive more. 4rth is one to one on both any way.
Sometimes transmission surge when searching because the load and low gear in too low an RPM. The trans doesnít kick down (downshifts) when caught in no-mans land.
Just wondering out loud. Iím on heavy cold meds....
Mine is the 545RFE as it is a 2011 model. It also only happens in high gear (5th/OD).
hur1ey02 is offline
post #28 of 176 Old 02-16-2012, 04:25 PM
l8tapex
2012 WK
hur1ey02
Do you think the transmission shift is too slow and soft when it has this type of load? (They know that owners are going off road, up and down hills etc.)
In other words, in reality, you want a crisp, quick, firm (not hard) shift. It reduces the clutch chatter/slippage .Saves the clutch pack wear. Just wonder if the pump pressure or valve body needs to be tweaked.
Hope you guys let us know what the techs tell you.
l8tapex is offline
post #29 of 176 Old 02-17-2012, 08:50 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
hurley02 and GreyGoose-
any updates?
post #30 of 176 Old 02-17-2012, 09:37 AM
WXman
I have a $5 bill that says I know what the problem is.
The torque converter springs are not strong enough for the torque being applied to them.
This was a RAMPANT problem with the 05-06 Liberty CRDs with the 545RFE transmission. The diesel torque was so high that it caused a shudder in the driveline when the converter would attempt to stay locked up in overdrive. Jeep eventually started replacing torque converters... but obviously this did NOT fix the problem because every torque converter they replaced it with had the same parts inside!
Around 2010 or so, Jeep finally released an updated torque converter that had stronger dampener springs inside of it. This cured 95% of all complaints about shuddering with the driveline. There was a great thread with photos posted in the JK section a few weeks ago.. see if you can locate it and you'll see what I'm talking about. Those of us with JKs and the 42RLE are having similar issues. Chrysler transmissions are higher quality than they used to be...but the engineers are putting s*itty torque converters in front of them.
I'm betting the Hemi is putting out more power than the torque converter is happy with on these Grand Cherokees. The problem will never go away until a STRONGER torque converter is used. Good luck.
Edit: Here's the thread
http://www.jeepforum.com/forum/f96/2...-help-1318651/
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
Newbie: transmission questions Denisk6106 WK2 Grand Cherokee Forum 3 08-27-2013 04:39 PM
Transmission questions AIB WK2 Grand Cherokee Forum 12 09-03-2011 01:33 PM
Transmission doesn't seem to shift right wjs81866 WK2 Grand Cherokee Forum 7 06-28-2011 07:43 AM
Transmission mysteries?? lords47 WK2 Grand Cherokee Forum 0 05-04-2011 01:06 PM
Transmission Issues BREJOLAW WK2 Grand Cherokee Forum 15 12-12-2010 05:17 PM
