Trans Temp? - JeepForum.com
post #1 of 8 Old 05-05-2013, 08:45 AM Thread Starter
dtrkyman
2013 WK
Trans Temp?
What temp is everyone's trans running? Mine seems to sit around 170-172, climbing a semi steep grade for only a couple minutes at less than 10 mph. and it climbed to 185.
I looked at a chart in a friends trans shop where it showed intervals for changing fluids based on temp. but not sure due to the fact it was a poster put out by a fluid manufacture.
Had Trans issues with my 01 so I am just trying to avoid them on the 13 I have. v6
dtrkyman is offline
post #2 of 8 Old 05-05-2013, 11:00 AM
loveracing1988
After driving 70ish miles mostly highway trans temp was at 192. This is a 14 v6 though.
loveracing1988 is offline
post #3 of 8 Old 05-05-2013, 06:55 PM
BobsWK2
2014 WK
MY 2014 Summit V8 trans temp reads higher than the 2012 Overland V8. I read somewhere that Chrysler designed it so the 8 speed is more efficient with the hotter trans temp. I just think the 8 speed operates at higher temps than the previous 5/6 speed trans.
2014 Summit 4X4 V8
BobsWK2 is offline
post #4 of 8 Old 05-05-2013, 09:21 PM
txwest
2012 WK
Originally Posted by BobsWK2 View Post
MY 2014 Summit V8 trans temp reads higher than the 2012 Overland V8. I read somewhere that Chrysler designed it so the 8 speed is more efficient with the hotter trans temp. I just think the 8 speed operates at higher temps thanthe previous 5/6 speed trans.
That is correct. My '12 runs at 150-180. Larger cooler and more fluid. New trannies are made to run hotter.
Sent from my S-III using JeepForum
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline
post #5 of 8 Old 05-06-2013, 10:37 AM
shekshishekki
2013 WK
i hover in the 170s even with a 2800lb trailer in the back.
shekshishekki is offline
post #6 of 8 Old 05-08-2013, 01:10 PM
Chris9674T
2011 WK
Same here. I have seen it peak in the low 180s after a long incline with the trailer, but even then the temp recovers pretty quickly after leveling out.
Chris9674T is offline
post #7 of 8 Old 05-13-2013, 06:48 PM
fd12me
ZF, a german manufacturer makes the 8 speeds, not Chrysler...although these days everything seems to be owned by FIAT... But you are right, the 8 speeds on the '14 run hotter. Mine ran 199 exactly when completely warmed up without skid plates. It ran at 205 with the skids--I thought that was odd, but I suppose logical as the transfer case and tranny heat is reflected back by the heavy steel plates.
I heard somewhere that 1hr or more at 250+ is bad...but then again I also heard, "don't worry about it, I'm on birth control once..."
fd12me is offline
post #8 of 8 Old 05-13-2013, 06:58 PM
loveracing1988
Chrysler makes the 8 speed for the v6, and soon they will be making the v8 version also.
