-   WK2 Grand Cherokee Forum (http://www.jeepforum.com/forum/f309/)
-   -   Trans Temp? (http://www.jeepforum.com/forum/f309/trans-temp-1518921/)
dtrkyman 05-05-2013 09:45 AM
Trans Temp?
What temp is everyone's trans running? Mine seems to sit around 170-172, climbing a semi steep grade for only a couple minutes at less than 10 mph. and it climbed to 185.
I looked at a chart in a friends trans shop where it showed intervals for changing fluids based on temp. but not sure due to the fact it was a poster put out by a fluid manufacture.
Had Trans issues with my 01 so I am just trying to avoid them on the 13 I have. v6
loveracing1988 05-05-2013 12:00 PM
After driving 70ish miles mostly highway trans temp was at 192. This is a 14 v6 though.
BobsWK2 05-05-2013 07:55 PM
MY 2014 Summit V8 trans temp reads higher than the 2012 Overland V8. I read somewhere that Chrysler designed it so the 8 speed is more efficient with the hotter trans temp. I just think the 8 speed operates at higher temps than the previous 5/6 speed trans.
txwest 05-05-2013 10:21 PM
Originally Posted by BobsWK2 (Post 15393525)
MY 2014 Summit V8 trans temp reads higher than the 2012 Overland V8. I read somewhere that Chrysler designed it so the 8 speed is more efficient with the hotter trans temp. I just think the 8 speed operates at higher temps thanthe previous 5/6 speed trans.
That is correct. My '12 runs at 150-180. Larger cooler and more fluid. New trannies are made to run hotter.
Sent from my S-III using JeepForum
shekshishekki 05-06-2013 11:37 AM
i hover in the 170s even with a 2800lb trailer in the back.
Chris9674T 05-08-2013 02:10 PM
Same here. I have seen it peak in the low 180s after a long incline with the trailer, but even then the temp recovers pretty quickly after leveling out.
fd12me 05-13-2013 07:48 PM
ZF, a german manufacturer makes the 8 speeds, not Chrysler...although these days everything seems to be owned by FIAT... But you are right, the 8 speeds on the '14 run hotter. Mine ran 199 exactly when completely warmed up without skid plates. It ran at 205 with the skids--I thought that was odd, but I suppose logical as the transfer case and tranny heat is reflected back by the heavy steel plates.
I heard somewhere that 1hr or more at 250+ is bad...but then again I also heard, "don't worry about it, I'm on birth control once..."
loveracing1988 05-13-2013 07:58 PM
Chrysler makes the 8 speed for the v6, and soon they will be making the v8 version also.
The time now is 12:45 PM.
