trans or diff Seperator plate TSB for clunk? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > trans or diff Seperator plate TSB for clunk?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!TJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 03-10-2015, 08:16 PM   #1
alludc
2012 WK
dropped off the GC today for a lil pre-warranty ending inspection and to fix a couple small things that bugged me. One of those was an occasional clunk when shifting to from d/r/p. They informed me there is a TSB for that issue and that they are going to install a Seperator plate in trans or diff, I forgot. They had to order the part so I took it home for the day. Anyone else have this done, heard of this?
theyre also replacing a leaky axle and fixing a rattling defrost vent in dash.
alludc is offline   Reply With Quote Quick reply to this message
Unread 03-11-2015, 08:19 PM   #2
alludc
2012 WK
no one?
seems to be http://www.wk2jeeps.com/tsb/tsb_wk2_2101012.pdf
Unread 03-12-2015, 07:32 AM   #3
DRKRED12
I had it done on a 2012 altitude hemi and it worked just fine. No more clunk. You should be fine.
DRKRED12 is offline   Reply With Quote Quick reply to this message
