Trailer hitch question - JeepForum.com
post #1 of 16 Old 11-27-2011, 10:32 AM Thread Starter
LMust145
If you buy the 2012 WK2 without the trailer and tow package, is it possible to add a hitch to the back??
LMust145 is offline
post #2 of 16 Old 11-27-2011, 10:47 AM
JeepOrvis97
JeepOrvis97's Avatar
ya but why do that? Just find one with the Hitch, most of them do as to what I see come through our dealer.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #3 of 16 Old 11-27-2011, 11:14 AM Thread Starter
LMust145
I ordered one from the factory. I have no need for a trailer and have no intention to ever trail anything, but was just curious if the dealer could install it later on.
LMust145 is offline
post #4 of 16 Old 11-27-2011, 11:14 AM
KevInSoCal
I was wondering the same thing as most WK2s I've seen do not have the tow package.
I called UHaul and they said approx $200 for a class III hitch.
KevInSoCal is offline
post #5 of 16 Old 11-27-2011, 11:16 AM Thread Starter
LMust145
My friend is a mechanic. he said that the car has the setup under the bumper already. All you would need to do is get the other bumper that exposes it.
LMust145 is offline
post #6 of 16 Old 11-27-2011, 01:32 PM
BManz
2011 WK
While you CAN add a hitch to the WK2 after the fact, it is much better to get it with the factory hitch already installed. The hitch is a Class IV, the wiring is already installed, and any transmission cooler lines are added at the factory. Adding wiring afterward is a hassle, IMHO, and I'd rather have all of that under warranty from the get-go than to add it later. It is very worth it to have the towing package factory installed regardless what the stealership or others might say. I'd add that this helps at re-sale time too.
BManz is offline
post #7 of 16 Old 11-27-2011, 08:52 PM
boostedboxer
2010 JK Wrangler
I know on my Hemi everything is there minus the receiver and the bumper cutout
boostedboxer is offline
post #8 of 16 Old 11-27-2011, 09:01 PM
dougy147
I'm not sure about the WKII, but I know my WJ was ordered (not by me) with a trailer prep package. This added a higher gear ratio, HD cooling and the trailer wiring harness, but not the actual receiver.
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
08 WK Laredo 4.7 (traded for tin can)
The Present
07 JK Unlimited Sahara
dougy147 is offline
post #9 of 16 Old 11-28-2011, 04:44 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
There have been many after the fact additions of a hitch. I'm sure there are photos and discussion in the archives, maybe a year ago. Its not a big deal.
ColdCase is offline
post #10 of 16 Old 11-28-2011, 06:12 AM
fljeepleo
2011 WK
The factory package comes with the load leveling rear shocks.
2011 Stone White Grand Cherokee Laredo E, ORA1, QT2, Factory Trailer Tow, 3m FX 15% Tint.
Retired Jeeps
1998 Wrangler Sahara 10inch skyjacker lift, 38x14.50 TSL
2005 Grand Cherokee Limited, 5.7, QD2
fljeepleo is offline
post #11 of 16 Old 11-28-2011, 04:13 PM
JAXKXX
Originally Posted by fljeepleo View Post
the factory package comes with the load leveling rear shocks.
Sent from my iphone using jeepforum
+1
JAXKXX is offline
post #12 of 16 Old 11-28-2011, 06:43 PM
azjack
2011 WK
Where is the info on the load leveling rear shocks? I've asked about the load leveling feature and no one seems to know. How does it work?
Jack
azjack is offline
post #13 of 16 Old 11-28-2011, 07:44 PM
rockspyder
Do a google search (or search here) on "Nivomat." That will give you some information, better than I can. Best thing, best I could tell, is that they are all mechanical, no electronics involved.
rockspyder is offline
post #15 of 16 Old 11-30-2011, 05:57 AM
ColdCase
ColdCase's Avatar
2011 WK
Jack
Basically the shocks have a set center position (length) that corresponds to the desired ride height. When the average position (shock length) moves off of that point, valves open and close and the up/down motion pumps fluid from one end to the other which, in turn, adjusts the ride height. There is not much more technical info available. They are completely mechanical.
You should be able to purchase them over the parts counter, shocks are replaceable wear items. I dunno the part number off hand.
ColdCase is offline
