TPMS on 2012 WK2 Laredo 4x4? - JeepForum.com
post #1 of 3 Old 08-22-2013, 09:40 PM Thread Starter
Niks76
Do all 2012 WK2 models have TPMS? I had a flat from running over glass that shredded the tire and by the time I pulled over it was completely flat. No TPMS message appeared though. I looked in my manual and it refers to TPMS but didn't know if my model doesn't have it. I also couldn't see any sensors on the wheels. I bought the Jeep new from a dealer in March of 2012. Thanks for any insight.
Niks76 is offline
post #2 of 3 Old 08-22-2013, 11:09 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
All 2012 models either have the TPMS warning or display. The warning lights a little lamp when pressure is low. The display also shows you the tire pressures. The TPMS sensor is the base part of the valve stem.
A tire shop can use their scanner and determine if there are sensors installed and if they are working. All models except the SRT8 use the same sensors. I think I read somewhere that pressure is sampled at 10 or 20 minute intervals, not continuously, but I dunno. So a blow out may not register unless you drive on it for while.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 3 Old 08-23-2013, 02:39 AM
loveracing1988
I belive in 2007 it became a federal requirement to have some sort of tpms on all vehicles.
loveracing1988 is offline
