towing question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > towing question
WIN a set of Mammoth Boulder Wheels at ExtremeTerrain.com!Savvy Aluminum Gas Tank SkidTruck & Jeep Fest 2015 - Edmonton
Unread 04-25-2015, 12:16 PM   #1
maznonno
2012 WK
towing question
I am correct in thinking that my 2012 overland v6, even though it has the factory hitch installed does not have any other features to aid towing? for example tow switch and ??
2012 Grand Cherokee Overland 4wd 3.6 v6
maznonno is online now   Reply With Quote Quick reply to this message
Unread 04-25-2015, 12:31 PM   #2
MuttJockey
Junior Member
MuttJockey's Avatar
Are there 7 and 4 pin outlets to the left of the hitch receiver?
MuttJockey is offline   Reply With Quote Quick reply to this message
Unread 04-25-2015, 12:35 PM   #3
maznonno
2012 WK
yes there are, figured that would be pretty standard though?
Unread 04-25-2015, 12:50 PM   #4
MuttJockey
Junior Member
MuttJockey's Avatar
You should also be pre-wired for the installation of an electric brake controller. Once it's installed, you have all the basic vehicle equipment needed with which to tow. Most RV dealers can supply nd hook up the controller.
If you are going to tow, research the towing capacity of the vehicle and the various load capacities as a start.
MuttJockey
Unread 04-25-2015, 12:52 PM   #5
maznonno
2012 WK
Thanks appreciate the info!
Unread 04-25-2015, 04:14 PM   #6
jim_in_PA
2012 WK
Do note that your limit is 5000 lbs and over 3500 requires a WDH.
2012 Grand Cherokee Overland Summit 5.7L V8 - Winter Chill with New Saddle Interior - Nitto NT421Q
jim_in_PA is offline   Reply With Quote Quick reply to this message
