Towing MPG... Good Lord!! LOL - JeepForum.com
post #1 of 29 Old 09-28-2013, 12:11 PM Thread Starter
gooberphx420
Guys,
Finally purchased my trailer. Lark 7x16 V-nose with tandem axles and power brakes.
Drove her 50 miles home from the dealer.
Averaged 10.5 MPG over hilly terrain. EMPTY!!!!! I also learned that cruise control is SILLY when towing.
2013 GC V6 2 2WD
The fuel to get me the 2000 miles back to AZ is gonna cost more than the trailer, LOL
gooberphx420 is offline
post #2 of 29 Old 09-28-2013, 12:35 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
V8 right? Something may be dragging? I routinely get 15mpg on a 6x14 flat front loaded to the brim and ~65mph hilly interstate.
Perhaps use tow/haul, if you have that button, with the cruise control. Works smooth for me.
What kind of mileage are you getting without a trailer?
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 29 Old 09-28-2013, 12:45 PM Thread Starter
gooberphx420
No sir, sorry. Should've stated: 2013 GC V6 2WD.
Avg day to day typical use ~20MPG, driving like an ***.
post #4 of 29 Old 09-28-2013, 05:56 PM
jim_in_PA
2012 WK
Even with that v-nose, you will still get a lot of wind-resistance that's going to knock down your mileage pretty quickly. Nature of the beast...
2012 JGC Summit Hemi
2016 Subaru Outback Limited
2011 Subaru Outback Limited
jim_in_PA is offline
post #5 of 29 Old 09-28-2013, 05:59 PM
rebelbowtie
Almost every SUV for pick up I have owned has returned worse MPG with v6 vs v8 in regards to towing. That's why I always get the larger engine except in the case of my XJ.
rebelbowtie is offline
post #6 of 29 Old 09-28-2013, 06:35 PM Thread Starter
gooberphx420
Aside from this one trip, I will probably never tow again. The V6 is just fine day to day. I was just shocked at how dramatic the MPG change was!
post #7 of 29 Old 09-29-2013, 11:54 AM
HaydenHunter
2014 WK
Hope that the wind is at your back during the haul. It helps on fuel efficiency...and hurts it if it is in your face.
Maybe you can stack that deck with route planning?
HaydenHunter is offline
post #8 of 29 Old 09-29-2013, 01:59 PM
loveracing1988
To be fair that trailer empty probably weighs in around 2700 pounds or so empty, and that's not taking wind resistance into account, so your already over halfway to your towing limit.
loveracing1988 is offline
post #9 of 29 Old 10-01-2013, 01:30 PM
zr2s10
2012 WK
That's a pretty big trailer to put behind the V6. Especially an enclosed trailer. But 10.5? Dang is that low! Wind resistance it a b!tch, lol.
zr2s10 is offline
post #10 of 29 Old 10-02-2013, 03:40 PM
webspoke
I am lucky to get 11 towing my 6x12 v-nose trailer with a Hemi, so this is not surprising. Even the v8 struggles with the wind load, I tow double the weight with an open trailer+car, and it is much less stressfull and mileage in the 12-13 range.
2013 White V8 Limited, 285/60/18 Terra Grapplers, 25000 miles problem free
2011 Black V8 Overland, retired at 46000 miles with QL problems
webspoke is offline
post #11 of 29 Old 10-02-2013, 10:23 PM
jaje
2007 WK
I get 17 - 20 mpg towing a 8x16 trailer with Miata, 2 sets of racetires on a rack (has some big wind resistance) and other gear loaded inside my WK. As I have to tow frequently I bought a CRD specifically for the huge fuel savings when towing.
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #12 of 29 Old 10-03-2013, 03:32 AM
WvTaco
2011 WK
take off alittle slower and dont try to out run everyone. do the speed limit on the highway no need for 70+ mph.
also check you ball for its max capacity. had a friend recently buy a 2in ball that was rated at 3500lbs. i had him throw it away, well no he put it on his atv. and bout one rated for 7500lbs.
i usually tow a 6x16 open deck, but dont expect to get above 13 mpg.
WvTaco is offline
post #13 of 29 Old 10-03-2013, 03:48 AM
loveracing1988
I don't know about you but 70 is the speed limit here, and most of the time going 70 you are still getting run off the road and passed like you are standing still.
post #14 of 29 Old 10-03-2013, 07:29 AM
clg82
I just did the same thing as the OP (purchased a new to me travel trailer) and I was also as others have said averaging 15 mpg after driving home 120 miles....i also have the Hemi V8 tho.....and was driving thru some very large grades thru the mountains on the way home.....i used cruise most of the way and left it in tow/haul mode, so not sure why you said towing with cruise on was a joke....stayed and 60 where I set it for me.
clg82 is offline
post #15 of 29 Old 10-03-2013, 07:29 AM
jaje
2007 WK
It's also 70 mph mainly where I live and I go faster when I'm in a car but when I'm towing I go 60-65 mph and simply set the cruise. When you almost double the weight of your vehicle it's not the smartest thing to have to drive as fast as everyone else. Just stay out of the way - time your passing (if you have to carefully) and keep an eye on your mirrors. Your mpg is much better, you don't abuse the trailer and tow vehicle as much trying to drive it like the trailer wasn't attached.
'13 Subaru BRZ
jaje is offline
