Towing limits? - JeepForum.com
post #1 of 5 Old 04-02-2013, 10:40 AM Thread Starter
Jeffro3000
2010 JK Wrangler
Towing limits?
I have a 2013 GC with the 6 cyl. My tow package was installed at the dealership. Depending where you read i can tow either 3.5k or 5k. If 5k is possible how close to the 5k is recommended. Reason being, i want tow my 2 door JK. If i got one of those 2 wheel trailers it would save on weight.
So, I'm wondering if it's possible or just forget about it.
2.5" OME HD lift, OME Steering Stabil, Skid Row Engine Skid, Skid Row Evap Skid, Ace Front Bumper, Ace Rock Rails, Engo 10K winch, Uniden 510 CB, 315/70R17 on Level 8 ZX
Jeffro3000 is offline
post #2 of 5 Old 04-02-2013, 02:55 PM
NDSU_Bison
2014 WK
It's interesting that the 2013 user guide says you can only tow 3,500 lbs without the factory tow package. My only guess is that's because it includes the trailer sway control since the heavy-duty cooling and higher gear ratio is only offered with the Trailer Tow IV which is only available on the Hemi.
I towed a 5,000 lb travel trailer with a 98 Cherokee with the 4.0 liter and no factory tow package twice before getting a bigger vehicle. You might be OK in Illinois, but climbing long grades in the mountains sent the temp guage up near the warning level and it wasn't even hot outside.
NDSU_Bison is offline
post #3 of 5 Old 04-02-2013, 05:42 PM
WvTaco
2011 WK
if u have tow package and a weight dist hitch i say 4900 wet. including trailer.
\2 door jk is about 3700- 4100, i would do it. the 2 wheel trailer is maybe 250lbs. but does it have brakes?
my 16 foot double axle is 1800 empty( well alittle under but i like to round up another 100 lbs.) . so some are even lighter. and are alot better to pull than the car dolly.
WvTaco is offline
post #4 of 5 Old 04-02-2013, 05:50 PM
Kev M
2012 WK
Looking at the differences between the OEM towing package and aftermarket, along with the historic differences in tow ratings between US spec models and identical models overseas in less litigious environments makes me say BULL S*#! to the 3500 number.
Kev M is online now
post #5 of 5 Old 04-02-2013, 05:55 PM
jeepsnmopars
I don't believe a two wheeled dolly is recommended for towing a JK. I think flat towing is your best option. I plan to do this with my JK this summer with a motorhome and most are only rated 3500 to 5000lbs for towing. Braking systems can be used in the JK and you will hardly know it is there.
1992 Sahara "the dull chain saw"
2012 JK 2dr
1968 Barracuda Formula S
jeepsnmopars is offline
