Tow Package Question - Page 3 - JeepForum.com
post #31 of 40 Old 06-19-2014, 09:27 AM Thread Starter
spinxt
Originally Posted by Ken-G
Thank you for your opinion, however I have been bit before for not asking enough questions or providing all of the information on my intended use of a vehicle. Bottom line it does not matter if the vehicle is capable of towing 10,000 pounds, if Chrysler is only going to warranty it for 5,000 lbs then that is my limit until the 100,000 mile power train warranty expires. How many parameters does the ECU record? Can Chrysler tell you were towing when a failure happened. Considering what a PITA it is just to get Chrysler to do warranty work, I'd hate to be 1,000 lbs over a limit and needing a new engine and transmission... Even if towing was not the cause of the failure you can bet Chrysler will use that fact to wiggle out of warranty work.
Perhaps but they certainly can't tell how much you were towing.
spinxt is offline
post #32 of 40 Old 06-22-2014, 07:46 AM
10Xk
2014 WK
What is your GCWR?
10Xk is offline
post #33 of 40 Old 06-22-2014, 08:59 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
What sometimes happens is a dealer will notice what you are towing an make a note on your VIN record. There have been a couple transfer warranty claims denied because the vehicle had an oversize tire note. The note got placed when they had to stop at an out of town dealer for an unrelated emergency repair.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #34 of 40 Old 06-24-2014, 08:47 AM
maverick12
Our dealer said they would install the receiver for $750 (same price as the towing package) on any of the non-towing package units they had in inventory. I'm sure it could be done elsewhere for much less, but we opted to order ours with the tow package to get the load leveling shocks, full size spare and extra cooling. I have a truck for towing, so I doubt we will tow much, if ever with the GC. Since we downsized from a Tahoe, however, I think it is likely that we will use a receiver rack which will likely be pretty weighted down so the load leveling shocks should help there.
maverick12 is offline
post #35 of 40 Old 06-24-2014, 08:53 AM Thread Starter
spinxt
What a rip off!!! I spend $240 on the receiver and installed in my driveway in less than 1 hour.
spinxt is offline
post #36 of 40 Old 06-24-2014, 10:36 AM
canistel
2012 WK
Did you need to buy wiring? I just called for a quote on an aftermarket receiver and the guy said it would be $240 - $250 for the hitch and another $80 on wiring. Seems a little steep on the wiring , I thought our jeeps (mine is laredo / base package) came with all the wiring needed??
canistel is offline
post #37 of 40 Old 06-24-2014, 10:52 AM
drcoopster
2014 WK
The wiring is there but they still need to hook it up.
drcoopster is offline
post #38 of 40 Old 06-24-2014, 07:00 PM Thread Starter
spinxt
The wiring is there if you have a 2014, you physically plug it into a separate electrical connector that clips into the hitch assembly. The dealer just has to "activate" it in the computer.
No reason to go aftermarket... The Mopar one is less expense and a much cleaner install...
spinxt is offline
post #39 of 40 Old 06-25-2014, 11:51 AM
10Xk
2014 WK
10Xk is offline
post #40 of 40 Old 06-26-2014, 09:57 AM
bobafettt
2014 WK
Originally Posted by 10Xk View Post
great read...thank you
bobafettt is offline
