-   WK2 Grand Cherokee Forum (http://www.jeepforum.com/forum/f309/)
-   -   Tow Kit Install...Anyone been through it? (http://www.jeepforum.com/forum/f309/tow-kit-install-anyone-been-through-1523008/)
fd12me 05-13-2013 07:31 PM
I was a little dissapointed to look at the rear bumper of my '14 limited and see no tow kit. I tow on a fairly limited basis, but need it from time to time. I was assured at the dealership (I know, I know, they'll say anything to get you out the door) that the aftermarket install by Jeep looks just as it does from the factory...my question: has anyone been through it (I know that results will change by dealership, I'm in the North Shore MA area), but have you gotten good results...or horror stories?
NYWk266 05-14-2013 07:26 AM
Just had the factory tow kit installed on my 2011 Laredo X. This included the hitch, trim plate and wiring harness. Looks 100% factory and cost about $400 installed. Added the jeep receiver plug and looks great. Don't go aftermarket add the factory tow kit.
Sent from AutoGuide.com App
Oteh302 05-14-2013 11:46 AM
Word of caution. Check owners manual on towing. Adding just a hitch may not be equivalent to the the factory tow package even if installed at the dealer. Factory package may include an external transmission cooler and different gear ratios. Even short trips pulling over what is recommended could drastically shorten the transmission life span.
Sent from AutoGuide.com Free App
NYWk266 05-14-2013 01:50 PM
I believe all Wk2 come with a transmission cooler, maybe missing an oil cooler? But you are correct in that adding the package after the fact limits tow capacity to 3,500lbs. I believe because adding the hitch does not include the load leveling shocks.
Oteh302 05-14-2013 02:00 PM
I wasn't sure or not. I know our 98 Durango with 5.9 is only rated for 1500 or something ridiculous, without factory equipped.
mx71 05-15-2013 09:41 AM
I put on a factory tow kit on my 2010 and an aftermarket on my 2012 and 2013. The aftermarket one goes on SO easy! I towed a 3500 lb trailer from CA to ID with the 2012 V6 and it rode awesome! So far with my 2013 4x4 Hemi, I've only hauled a Moto Carrier, but you don't even feel it back there.
Dabitz 05-15-2013 02:56 PM
1 Attachment(s)
Here is how the aftermarket looks like if you want to go that way. Barely noticeable under the bumper cover. I wanted mine for a bike rack only so I wasn't going to spend +$400.
Attachment 626935
BobsWK2 05-15-2013 04:20 PM
Attachment 626935
That aftermarket hitch sure is a lot lower to the ground than the factory hitch. Not good for a 4X4.
gdash722 05-16-2013 11:21 AM
I purchased the Mopar hitch and wire harness and had it installed for about $475 (they guy said that he could never do it for that low again due to the cutting of the bumper, soldering into the wire harness, and reflashing the system to get the blinkers to work) and am very pleased. It looks stock and very clean. Like BobsWK2 said, the aftermarket hitch is no good for off-roading, due to it killing your angle of departure (but it will protect your bumper more if you were to hit something). If you don't plan on taking it off road and you don't mind the look of the hitch under the bumper, save yourself a couple hundred dollars and get the aftermarket.
RUSH-2112 05-16-2013 11:51 AM
1 Attachment(s)
Took almost 3hrs at the dealer with total cost of $575.00. Very stout class 4with no issues.
Justal13 05-16-2013 03:10 PM
Yes, hitch and wiring are the same if the dealer installs the OEM kit. However, for a very reasonable price from the factory you would have gotten:
V6 Trailer Tow Group IV $795
•7 and 4 Pin Wiring Harness
•Class IV Receiver Hitch
•Delete Rear Tow Hook
•Rear Load Leveling Suspension
•Full Size Spare Tire
•Steel Spare Wheel
•220-Amp Alternator
•Heavy Duty Engine Cooling
This package for the 2014 will give you 6,200 lb towing rating. On the 2011-13 models, the capacity is 5,000 lb. I guess if you don't need the capacity, doing the install after delivery by the dealer or an after-market hitch might be acceptable. Personally, I would not tow over 5,000 lb with the V6. And that is a push IMHO depending upon the frontal area of what you are towing. I always order the towing package from the factory, and on the GC the price/value is there considering all that is included.
inhidin 05-20-2013 07:42 PM
would anyone know if the rear springs are different with/without factory tow package? i understand you get nivomat shocks and all the other goodies, but the the spring rates different?
mx71 05-21-2013 11:43 AM
It's actually come in handy for me. I was going up this little hill and being that I don't have skid plates, I would have ripped my bumper off, but I just scraped this instead. Pretty happy about it.
NYWk266 05-21-2013 11:53 AM
I believe rear springs have to be different in order to be compatible with the Nivomats. At least that's how it was with my Challenger with the super trak pak and Nivomats.
inhidin 05-21-2013 01:38 PM
Thanks for the info.
The time now is 12:27 AM.
