Tow Hooks Install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Tow Hooks Install
50" LED CREE Light Bar Pair With Wiring KitFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 01-25-2015, 02:08 PM   #1
gfviperman
2013 WK
Tow Hooks Install
Have a 2013 Overland.
Will be installing Mopar Two hooks.
Has anyone done this?
Looks to be straight forward ... but one never knows.
Thankx!
gfviperman is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 02:31 PM   #2
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I don't recall anyone posting instructions here but many have installed them. Just follow the instructions in the kit. They can be a PITA and takes about 2 hours if you are handy and things go right. Run all the bolts through all the nuts as you should with any mod kit. The nuts seem to be a PITA to get started and hold from turning, you don't want to be doing this twice just to clear threads.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 03:33 PM   #3
FreeJersey
2014 WK
Thankx!
Yes, very straight forward. As Coldcase said, just follow the instructions. Not a bad job at all.
I have to take mine out to install my RRO Bumper guard, but can't find the instructions from when I did mine. Could you post the torque values from the instructions?
FreeJersey is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 05:39 PM   #4
gfviperman
2013 WK
16mm bolts - 35 ft lbs
18mm bolts - 35 ft. lbs
30mm bolts - 18 ft lbs
OK, now go make a movie!!LOL
Unread 01-25-2015, 05:54 PM   #5
gfviperman
2013 WK
Got the two hooks from a friend who had to have his two hooks removed for a tow bar install.
Got everything except the spacers and the cover plate for the 18mm bolts.
If you can give me the size of the spacer and the dimensions of the cover plate, it would be greatly appreciated.
Unread 01-25-2015, 06:08 PM   #6
FreeJersey
2014 WK
Sure can...If you can wait until the spring..
I appreciate the torque values, but I have no intentions of tackling this job until it warms up a bit. Facing a blizzard tomorrow, then it looks like 2 weeks of sub freezing weather.
Unread 01-25-2015, 08:09 PM   #7
PipesTA
2 hours???? I've done a few Jeeps in about 30 minutes. Shouldn't take more than 30-45 with some simple hand tools.
'11 WK2 - 5.7, Limited
'99 WJ - SOLD
'96 ZJ - SOLD
'95 T/A, few doo-dads ;)
PipesTA is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 09:05 PM   #8
ColdCase
ColdCase's Avatar
2011 WK
If you know what you are doing and have the dexterity and expertise maybe 45 minutes, if not at least 1 1/2 hours. 2 Hours seems to be the norm. Heck its 30 minutes just to gather up the tools
Unread 01-26-2015, 10:04 AM   #9
gfviperman
2013 WK
http://www.youtube.com/watch?v=PKKz3_C0vrc
She's Hired!!!!
Unread 01-26-2015, 11:17 PM   #10
wyat72
2011 WK
Interested in doing this on my Jeep as well. Thanks for posting.
2011 Grand Cherokee Laredo X, Pentastar, Qudra Trac I.
wyat72 is offline   Reply With Quote Quick reply to this message
Unread 01-28-2015, 06:39 PM   #11
JeepingNet
Anyone consider doing the front tow hitch instead? In canada the hitch is actually the cheaper.
Colin Jennings
Trail - TBD
Daily - 2011 Grand Cherokee Overland v8
JeepingNet is offline   Reply With Quote Quick reply to this message
Unread 02-13-2015, 08:26 PM   #12
lawdocjoe
All - my 2015 Altitude should arrive this week. The dealership is telling me that in order to install tow hooks, they will have to CUT the fascia. This makes NO SENSE to me. Can anyone help? Thanks.
lawdocjoe is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 12:48 PM   #13
ChuckWag78
what do you guys use to pry out the little push button clips that hold the bumper? Any best practices for removing?
I always seem to break these things when I try prying with just a screwdriver.
Thanks
ChuckWag78 is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 03:28 PM   #14
DRKRED12
Go to one of your local parts store as they make a special tool. Looks like a two prong fork.
DRKRED12 is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 11:34 AM   #15
2kg4u
2014 WK
Nay, nay. If you just try prying the clips you will break them for sure. I have not looked at the bumper clips yet, but the two types of clips I have seen so far on my 14 JGC are the type where you have to pry out the center core in order to release the clip, and the type where the center core is a small plastic pin you have to drive through to release the clip. If you don't remove the core sections the clip remains expanded and prying on it, even with the correct tool, will break it. The only type of clip you can just pry out is what is referred to as a Christmas tree clip ... these rely on the interferance fit created by numerous thin ribs that are perpendicular to the main core of the clip, rather than a center feature you push in to expand the back side of the clip.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline   Reply With Quote Quick reply to this message
