Tom's 2013 Jeep Grand Cherokee Altitude - Page 9 - JeepForum.com
post #121 of 133 Old 03-16-2014, 08:41 PM Thread Starter
SilverbackWK
2013 WK
Originally Posted by JMP8562 View Post
Question, the antenna cable end comes off the side what is that type of cable called
Firestik calls this cable 'SINGLE ANTENNA COAX with PL-259/FireRing Termination'. The end is their own design.
2013 Grand Cherokee Altitude, 3.6L, 275/65/18 BF Goodrich TA KO, MTB KO 18", RRO 2.5" Lift, BWoody Extended Sway Bar Links, RRO Winch Mount with Combo Bar (modified), Warn Zeon 10-S Winch, RRO Sliders, Mopar Hitch and Tow Hooks, Rigid Industries Lights, GoPro Hero3 Black edition, Cobra 75WXST, 4' Firestik II
SilverbackWK is offline
post #122 of 133 Old 03-16-2014, 08:47 PM Thread Starter
SilverbackWK
2013 WK
Originally Posted by Jackal01 View Post
My swr is off the meter. 10+. No idea why. Bought a FS 2 3 foot after the Wilson flex 4 that came with the kit. Gonna ser which tunes better but both aren't tuning.
Did you read any of this yet? http://www.firestik.com/Tech_Docs.htm Was pretty helpful. I don't know if I'd be concerned that the antenna mount is not attached to metal. Yours is mounted into plastic, right?!? I think, but don't quote me, as I am a beginner, but even though the antenna doesn't need a ground wire, the mounts should still be grounded metal to metal. See http://www.firestik.com/Tech_Docs/Setting_SWR.htm
post #123 of 133 Old 03-17-2014, 06:57 AM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Right. Our antennas are not NGP. They need to be attached to metal. I first mounted it to the grey plastic not thinking about that (doh). I now have it mounted a little higher than yours, about 8 inches up. I need to get the cable you have because mine will rub the paint. What little time I spent tuning it the SWR wouldnt change. I know it will take a while since the window for SWR is relatively small but man...just discouraging. This is my third or fourth CB and I have never had this much trouble.
2011 Billet JKUS
Jackal01 is offline
post #124 of 133 Old 04-20-2014, 10:17 PM
06_footy
1977 J-Series Truck
Your rig is the inspiration to do some nice modifications to my wife's 2011. Since you have wheeled your ride with the RRO lift. What is your opinion of it?
1977 Jeep J10 (Project)
AMC 360, Quadratrac, Long tubes w/ cat's deleted, True dual exhaust
2011 Jeep Grand Cherokee 4wd (Wifes)
Stock
06_footy is offline
post #125 of 133 Old 04-21-2014, 08:05 AM Thread Starter
SilverbackWK
2013 WK
Thank you.
The RRO kit isn't bad. I don't feel like installing the kit makes my rig unstable, and the added height is very nice. Wouldn't have been able to put the larger tires on it. Just wished there was a better, suspension lift for it... ...but there isn't!
I would recommend the RRO kit.
post #126 of 133 Old 05-30-2015, 08:18 AM
rpmurray
2013 overland w/ hemi has no balls...
does anyone else here have the 5.7? i have never driven anything so damn slow in my life, its sad. im trying to figure out how the liven her up..
rpmurray is offline
post #127 of 133 Old 05-30-2015, 04:09 PM
13ovsummit
2013 WK
^^^ - Doesn't sound right to me! My copy has lots of pep for a vehicle of this size/weight. Have you checked the intake filter lately?
13ovsummit is offline
post #128 of 133 Old 05-30-2015, 07:26 PM
spinxt
There's got to be something wrong with yours. Mine is quick. You have to remember you're driving a 5k+ lb vehicle.
spinxt is offline
post #129 of 133 Old 06-01-2015, 08:18 PM
lawdocjoe
The 6 Cyl skoots! Sings opera when you open her up. Hard to believe the 8 is slow.
lawdocjoe is offline
post #130 of 133 Old 06-02-2015, 11:20 AM
DRKRED12
Just trying to figure out why we would revive a year old thread about lift kits to talk about the lack of power of a hemi. Why not just start a new thread. Maybe ColdCase could separate the two.
DRKRED12 is offline
post #131 of 133 Old 06-02-2015, 11:39 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I was hoping this thread would just fade away. There are so many other power threads.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #132 of 133 Old 06-02-2015, 06:12 PM
DRKRED12
Got it. Thanks ColdCase for responding.
DRKRED12 is offline
post #133 of 133 Old 09-09-2015, 06:15 AM
vcustoms
2012 WK
How is the lift on the jeep holding up? Any complaints or issues relating to lifting it?
I have a 2012 altitude and was hoping to lift it in the future but was hesitant to do so as not many are lifted/not too many parts to lift with.
vcustoms is offline
