Tire noise, wheel bearing, or other? - JeepForum.com
post #1 of 7 Old 04-20-2012, 06:29 PM Thread Starter
UNCjeepWK2
2011 WK
I recently had my WK2 serviced and tires rotated. I noticed a subtle wup-wup-wup noise that sped up and slowed down w/ the speed. I thought it might be simply the tires evening out after being rotated... but I've driven over 1k miles since the rotation... so I'm confused.
I checked the tire pressure and they were at 32... which is a little low... so I increased each to 36. But still, the noise persists...
Again, it's pretty subtle, but definitely there. You can hear it... and feel it some in the pedals and steering wheel. Occurs mostly in the 20-50 mph range.
I couldn't imagine a wheel bearing going bad at 28,000 miles...
Any ideas?
UNCjeepWK2 is offline
post #2 of 7 Old 03-06-2013, 04:06 PM
heronbelei
Mine is with the same problem. Did you discover where the noise came from?
heronbelei is offline
post #3 of 7 Old 03-08-2013, 10:03 AM
Dave2002ti
2012 WK
bad tire
Try rotating the tires and see if the noise moves or stops.
Dave2002ti is offline
post #4 of 7 Old 03-08-2013, 11:22 AM
heronbelei
Noise continues even if tires are rotated
post #5 of 7 Old 03-08-2013, 11:33 AM
Dave2002ti
2012 WK
Tires
Crapyears or Michelins? Still could be the tire
post #6 of 7 Old 03-08-2013, 11:34 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Look for grease or something stuck to the inside of the wheel, throwing things off balance. Check the tightness of the lug nuts, but if you tried rotating tires I guess they are tight. Look for something that could throw the axles or drive shafts out of balance, or something wrapped around them. Otherwise, if they serviced the transaxle or diff, check oil level. Ask what brand and weight oil they used.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #7 of 7 Old 03-14-2013, 09:39 PM
Blondi5858
2011 WK
I was having the same problem. Didn't think it was a wheel bearing since I only have 32k miles.
Figured it was the crappy Michelins so it gave me an excuse to buy new tires :-)
It got rid of a little of the road noise, but i was still having the wobble and wup-wup noise.
Brought it to the dealer right after and found out I actually do have a bad wheel bearing on the front right side.
Blondi5858 is offline
Wheel and Tire Discussions Timgco WK2 Grand Cherokee Forum 2577 Yesterday 12:27 PM
Is the 2011 Quadra Drive 2 a 3 wheel or 4 wheel drive system? MRK WK2 Grand Cherokee Forum 45 11-03-2015 12:22 PM
Bad Noise GaryGC WK2 Grand Cherokee Forum 13 03-09-2012 09:13 PM
Rubicon Wheel and Tire ? Louisb WK2 Grand Cherokee Forum 4 02-28-2012 07:12 AM
v8 Engine noise GC2011BBP WK2 Grand Cherokee Forum 13 09-25-2010 07:06 PM
