Synthetic Brake Fluid? - JeepForum.com
post #1 of 11 Old 06-28-2013, 09:21 AM Thread Starter
Dabitz
2015 WK
Question Synthetic Brake Fluid?
Is anyone using Valvoline Synthetic brake fluid? (DOT 3 & 4, Surpasses specifications SAE J1703 and FMVSS No. 116)
I'm flushing my brakes this weekend and was thinking about switching to this. Anyone using?
Dabitz is offline
post #2 of 11 Old 06-28-2013, 09:25 AM
Dave2002ti
2012 WK
Never tried it
What is the wet boiling point? I would stick with the old standards Castrol LMA, Ford Heavy Duty and ATE Blue and ATE Gold.
My favorite fluid is ATE Blue and Gold since they make it easy to tell when you get to the new fluid. Be careful with racing brake fluids since they are extremely hydroscopic and require fluid changes before a race weekend and therefore they shouldnt be used in daily drivers.
Dave2002ti is offline
post #3 of 11 Old 06-28-2013, 09:37 AM Thread Starter
Dabitz
2015 WK
From their site:
Compatible with all braking systems requiring a DOT 3 or DOT 4 fluid
Mixes well with conventional fluids
High dry boiling point up to 480F reduces the risk of fluid evaporation and possible brake failure
Low-moisture formula provides excellent vapor lock protection
Maximizes ABS performance
Ideal for hydraulic and disc brakes
Surpasses specifications SAE J1703, FMVSS No. 116 and DOT 4 Motor Vehicle Brake Fluid
Minimum wet boiling point is 311F
It seems to have good reviews all over the interwebs. http://www.valvoline.com/products/co...brake-fluid/28
Dabitz is offline
post #4 of 11 Old 06-28-2013, 10:19 AM
Dave2002ti
2012 WK
You might want to read
Some of Porsche or BMW track day forums ie Pelican Parts, PCA, BMWCCA etc.
Again dry boiling point is worthless since once you open the can brake fluid starts to attract water. Wet boiling point is the most important. ATe Gold has a wet boiling point of 399 degrees. Do a google and see what folks have to say.
If you tow I would change the fluid every year.
post #5 of 11 Old 06-28-2013, 10:56 AM Thread Starter
Dabitz
2015 WK
Thanks Dave... I see Ate is the best out there. I don't tow at all so maybe the Valvoline is good option to try. Wet boiling point is 311 I believe and has good reviews. Trying to pick something that is available off the shelves.
Dabitz is offline
post #6 of 11 Old 06-28-2013, 11:52 AM
NCJeepGC
2012 WK
Used Valvoline in my Ram before I bought my Jeep. Great product. Never let me down. And its readily available.
2012 Jeep WK2 Laredo 4X4
NCJeepGC is offline
post #7 of 11 Old 06-30-2013, 09:26 PM
rudeney
2014 WK
I've been using ATE in all my cars for many years. Other than the wife's Jeep, we've had mostly Mercedes-Benz which call for fluid changes every two years and the ATE fluids exceed their specs. I alternate blue and gold to make it easy to see the change in color.
rudeney is offline
post #8 of 11 Old 07-01-2013, 06:33 AM
l8tapex
2012 WK
Ford Racing Blue is 500 WBP but unless your at the track I dont think you will need special brake fluid. Just quality. ABS and stock pads have reduced the heat so much that even pad and rotor wear is is crazy good. I l8t brake my JGC a lot for the last year. No fade.....yet
________________________
2012Overland 4 X 4 Deep Cherry Red Crystal Pearl Coat, SRT8 Hood and Spoiler
l8tapex is offline
post #9 of 11 Old 07-01-2013, 07:10 AM Thread Starter
Dabitz
2015 WK
I agree. I changed my brake pads at 50K miles and they still had plenty of meat on it.
Dabitz is offline
post #10 of 11 Old 07-01-2013, 11:11 AM
Dave2002ti
2012 WK
Actually
Its 399 degrees for the Wet Boiling Point.
post #11 of 11 Old 07-01-2013, 12:08 PM
97HMCS
2012 WK
I was under the impression that all DOT 3 & 4 brake fluids are synthetic and are made from glycol-ether base.
I have heard of silicone based brake fluid referred to as synthetic, but that would not be the correct brake fluid for the WK2.
97HMCS is offline
