Starting issues? 2012 Summit - taking several tries to engage starter, bad battery? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Starting issues? 2012 Summit - taking several tries to engage starter, bad battery?
Bds fox ipf 2.0 racing series shocks now available at rockThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread Today, 08:24 AM   #1
shudog
2012 WK
Last 2 weeks my Jeep has not started when I push the brake & hit the "start" button. Takes 3-4 attempts to cycle through the on/off, start, off & retry before it finally tries to start. When the engine turns over, it always starts but it's just not engaging the starter. I think this little heat wave we are experiencing is killing the battery. Jeep is a 2012 with 60k miles, original battery. Thoughts?
What's everyone suggest for a battery?
Previously owned jeeps:
'06 Grand Cherokee Limited w/4.7L V8 & QD2
'98 Grand Cherokee Limited w/5.2L V8 & Quadra Trac - sold at 230k miles
shudog is offline   Reply With Quote Quick reply to this message
Unread Today, 11:03 AM   #2
wyat72
2011 WK
Sounds like the TIPM is starting to fail. Has the recall been performed?
2011 Grand Cherokee Laredo X, Pentastar, Qudra Trac I.
wyat72 is offline   Reply With Quote Quick reply to this message
Unread Today, 01:43 PM   #3
MidLifeinMI
2012 WK
Don't think it's the TIPM, since the engine *will* crank with that issue (just won't get any fuel). Sounds like it's likely the battery. When it fails to start, does it do anything at all when you press the start button? Any noise?
2012 GC Limited, 3.6L, QuadraTrac II
MidLifeinMI is offline   Reply With Quote Quick reply to this message
Unread Today, 05:43 PM   #4
wyat72
2011 WK
Yep, I agree. I didn't read his thread close enough.
