SRT in Buffalo Winters? - Page 2 - JeepForum.com
post #16 of 38 Old 11-14-2013, 10:17 AM
MattXJ
2014 WK
I think that might be a little short-sighted on the part of the dealership. I can understand why they would want to go with the easy/safe answer though. Likely 1. they have to assume that the buyer won't invest in a good quality winter tire set-up, and/or 2. they're not familiar with how to work around the challenges in finding wheels/tires to fit the SRT in a narrower than stock configuration to allow for #1.
I strongly believe that if you go down to a narrower tire for winter, get the correct sized wheel for that tire, and buy a good quality (true) winter tire you'll be all set.
The SRT offers tons of technology to deal with snow conditions. There's a Snow mode, which optimizes the 4x4 torque split, shift patterns and throttle sensitivity. There's advanced traction control, and an ELSD in the rear diff.
I can't see how you wouldn't fare out equally as well as any other model JGC.
NB. driver common-sense is implied, regardless of the rig
89 XJ (Ltd): RE 3.5", full leafs, 3/4" coil spacers, RE monotubes, JKS Adj trac, tcase drop, OME steering stab., BFG AT 31x10.5xR15s on 15x8 3.75bs, Borla cat-back
14 WK2 SRT: DiabloSport catch can, Borla S-Type
MattXJ is offline
post #17 of 38 Old 11-14-2013, 05:47 PM Thread Starter
RllyDrvrIX
2015 WK
Guys making it hard for me to stay with the '12 Overland....
2015 JEEP Grand Cherokee Altitude; All stock....
RllyDrvrIX is offline
post #18 of 38 Old 11-15-2013, 12:25 PM
Diode Dynamics
Jeep Lighting Experts
Diode Dynamics's Avatar
2011 JK Wrangler
Nick C.
Your Source For Jeep Lighting
We provide the highest quality products around! check us out! >
Diode Dynamics is offline
post #19 of 38 Old 11-16-2013, 07:48 AM
Gunny7
2014 WK
Thing I have read and seen is, unless you have the locking rear end, -The off-road Adventure package- all of these things have a traction control that brakes the spinning wheel.
In a slippery situation where all wheels might slip, seems to me, this system will just keep braking you down until you are stopped.
Is that possible.
The cars, except for the SRTs are like this.
Open rear differentials.
I don't know why Chrysler does this.
Gunny7 is offline
post #20 of 38 Old 11-16-2013, 07:54 AM
Gunny7
2014 WK
If I lived in Boston I would but some 20in steel wheels and snow tires for them. Brimstone Blizzard? Come to mind.
Put them on and go.
SRTs have the locking rear diff and all the bells and traction whistles.
Gunny7 is offline
post #21 of 38 Old 11-16-2013, 08:03 AM
LouC
2007 WK
I've driven both of my Jeeps in North Eastern winters and never needed 4low. If anything, the gear reduction of low will make it easier to get stuck on slick surfaces. I have used studded tires on both and they easily went through the worst conditions here. On the WK is was able to get factory steel 17"
Wheels ($77 ea) with the tpms valves ($40 ea) so the cost wasnt too bad. I have General Altimax Arctic studded on the WK.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is online now
post #22 of 38 Old 11-16-2013, 09:27 AM
loveracing1988
Is that possible.
It won't brake both sides at the same time, just the one that is spinning faster than the other. On most cars and trucks you can just shut it off as it will not only use the brakes but cut throttle too. On a Grand Cherokee (or any jeep with the brake lock differentials) you can shut off the traction control but keep the brake lock diffs, so you can spin the tires and it won't cut throttle. This is especially true with select terrain in the mud setting.
loveracing1988 is offline
post #23 of 38 Old 11-16-2013, 10:08 AM
LouC
2007 WK
My 98 ZJ has open diffs front and rear, no traction control and even with the selec trac 4x4 in the full time position, (open center diff) I never got stuck with snow tires. I was able to get some tail out behavior around turns, and if the conditions were really bad I shifted it into part time which locked the front and rear driveshafts and with that I could go anywhere. Keep in mind good winter tires benefit both turning and braking to a very significant extent. If you have the kind of job where you have to get to work no matter what, its a good investment. We have very steep hills and frequent icing conditions and the studded snows really help. In th norh east blizzard of Feb 8th 2013 I drove home in the WK in rush hour traffic, up hills that left front drive suv's hoplessly spinning wheels, the traction control came on only once for a split second, that's how much more traction the studded tires give you. This was about 6" of snow on top of ice on hills.
LouC is online now
post #24 of 38 Old 11-16-2013, 10:53 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Is that possible.
SRTs comes standard with ELSD, for most other wk2 models it is optional. In an SRT you don't want stinking brakes slowing you down
The mistake many drivers make when wheels start spinning is not mashing the throttle, the vehicle may slow, but you need to keep giving it gas to work. Otherwise it may just stop. Traction control applies pulsing brake action similar to ABS.
Locking diffs are expensive and do have some quirks.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #25 of 38 Old 11-16-2013, 11:04 AM
ColdCase
ColdCase's Avatar
2011 WK
Dunno what you mean by brake lock diff, maybe I'm not reading it right. Unless you have a WK2 with an ELSD, your diffs are completely open. Jeep uses the "brake lock diff" term for their brake traction control system. Other Jeep models may be different.
ColdCase is offline
post #26 of 38 Old 11-16-2013, 11:38 AM
loveracing1988
That's what I mean. But I mean you can drive around with the traction control on and it will cut throttle and apply brakes to transfer power. Or you can shut the traction control off and it will only apply brakes to transfer the power. The term brake lock differentials is what they used in the owners manual of my wife's.
post #27 of 38 Old 11-16-2013, 12:27 PM
LouC
2007 WK
All of the high tech electronics are only as good as your tires. Tires make traction not electronics. High speed rated tires such as those on the SRT8 get hard as a rock in freezing temps.
LouC is online now
post #28 of 38 Old 11-16-2013, 05:22 PM
xJoshxx
2012 WK
I've not driven my SRT yet in the snow but it's my new DD and I have the Verde All seasons, They seem to be decently soft in 30+ degree weather. and have a decent tread pattern they are not serve weather rated but, Im not Spending $2500 for a set of tires and rims i use 3 months out of the year. I drove in an Ice storm with my 2011 Laredo with stock fortera's in snow mode. the 4wd drive system is amazing compared to my WJ i used to have. When my verde's are used up prob by the end of summer next yr ill be doing DWS's because they have a 50k warranty.
The SRT has the snow mode all 2nd gear starts and 80% less throttle and 50/50 TQ split.
It's about the Tires and Driver.
Factory Repro's have a 20x9 gen1 SRT rim that fits the Wk2 Massive Brembo's then you can chose to put other size tires on it. a 265/50/20 will work.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #29 of 38 Old 11-18-2013, 02:40 PM
MattXJ
2014 WK
lol! Recommended reading: page 1 of this thread. Very good point tho, I completely agree... on page 1.
MattXJ is offline
post #30 of 38 Old 11-19-2013, 11:33 AM
LouC
2007 WK
The reason why I say this, is that in my region, no one uses winter tires unless they are skiers. Every time we get a bad snow storm, I see a number of high tech vehicles going no where, on all season or even worse high performance tires. I know that with anything more than a 17" rim we get into an expensive proposition when you add it all up, plus the TPMS sensors add to that. BUT, if you avoid an accident or two over the years....not a bad investment....plus your regular tires last longer, because they are not used in the winter months....
Tire tech has come so far that I'm considering a Dodge Challenger R/T for a fun car, we had rear drives back in the day (70s--full size GMs) and the way we got around was primitive Firestone Town & Country studded snows (later on got more sophisticated and used Gislaved studded snows) and put 4 bags of sand in the trunk, I'm not kidding, for weight. Oh and our traction control? That was when you got stuck on ice on one side, you pulled out the release for the parking brake and pumped the parking brake pedal to send power across the open diff to the side with traction. Don't laugh it works.....
LouC is online now
