Spare tire diameter - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Spare tire diameter
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome savings at openboxoffroad.comNitro Gear Packages Now Available at Rockridge 4wd
Unread 01-30-2015, 04:38 PM   #1
ferntree
ferntree's Avatar
2014 WK
Spare tire diameter
Have just put larger diameter tires on the Overland. Will the standard spare (smaller) cause any damage to the driveline if it is used or should I get one to match?
2014 Overland Oiler, ORII, QD, Granite/Indigo Blue, rock rails, Cooper AT3's - oh yeah!!
Officer, these handcuffs are tight!
Just relax, they're new. They'll stretch after you wear them a while....
ferntree is offline   Reply With Quote Quick reply to this message
Unread 01-30-2015, 06:36 PM   #2
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
It would be fine for the short period of time it would take to get the road wheel repaired or replaced. It would put more wear and tear on the transfer case and may throw the ABS and stability control off a little, so I'd suggest driving conservatively.... no towing or 4low.. If you may have to drive on the spare for hundreds of miles, I'd get one the same diameter.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now   Reply With Quote Quick reply to this message
Unread 01-30-2015, 07:40 PM   #3
jim_in_PA
2012 WK
A very short period of time...like to get to somewhere to fix the flat, but not for "long term" use. The 4WD system doesn't like mismatched tire diameters.
2012 Grand Cherokee Overland Summit 5.7L V8 - Winter Chill with New Saddle Interior - Nitto NT421Q
jim_in_PA is offline   Reply With Quote Quick reply to this message
Unread 01-30-2015, 09:43 PM   #4
ferntree
ferntree's Avatar
2014 WK
Yeah - as I suspected. Better safe than sorry. Will get a larger spare as well.
Thanks guys!
Unread 01-31-2015, 09:12 AM   #5
jim_in_PA
2012 WK
Just match the diameter...you can go narrower so it fits under the lid just like the OEM spare. You'll likely have to pull out the storage bins to fit the larger tire, however.
