smoke at startup v8? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > smoke at startup v8?
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectBrand New! Quadratec LED Headlights!FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 08-19-2014, 09:12 PM   #1
kryogen
I noticed this morning a nice puff of smoke when starting the jeep [...]
I know there has been info about it and a possible fix?
Should I call the dealership and have them fix it or they wont? What did you guys do?
kryogen is offline   Reply With Quote
Unread 08-19-2014, 09:18 PM   #2
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Was it parked pointed uphill? How's the oil level? Some dipsticks are off and one can overfill. It is major surgery to install that new windage tray and it sometimes don't work anyway.
If its smoking after parked on the level or pointed down hill, the windage tray fix isn't going to help you.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now   Reply With Quote
Unread 08-20-2014, 05:21 AM   #3
kryogen
seemed parked level, should not be smoking right ?
Unread 08-20-2014, 07:08 AM   #4
ColdCase
ColdCase's Avatar
2011 WK
Water vapor yes, oil smoke should not.
Unread 08-20-2014, 09:49 AM   #5
14summithemi
2014 WK
Hugely discussed all around. Your 2011 has this TSB out there on it:
http://www.wk2jeeps.com/tsb/tsb_wk2_0900213.pdf
For what it's worth my '14 Hemi (built 12/6/13 so this TSB does not apply to me) has done this 3 times when parked on level ground. Since you are in TSB range you may want to consider this although you may have to pay for it unless you bought an extended service contract.
Oh, and don't think oil type matters as I use Amsoil Signature Series 100% Synthetic.
14summithemi is online now   Reply With Quote
Unread 08-21-2014, 03:58 PM   #6
kryogen
does it matter or it just doesnt matter? Not that I really care?
Unread 08-21-2014, 04:03 PM   #7
14summithemi
2014 WK
Does not matter imho...net net flat parking and TSB application (windage tray and programming module) may reduce it but it's just gonna happen once in a while on "some" hemi motors, mine is proof.
