Skids on 2012 Grand Cherokee Overland - Pics - JeepForum.com
post #1 of 15 Old 10-24-2011, 03:07 PM Thread Starter
wxchaser
2014 WK
Below are pics of the skid plates installed on my 2012 GC Overland:
wxchaser is offline
post #2 of 15 Old 10-25-2011, 03:08 PM
rockspyder
Are these different than the regular Off-Road plates?
rockspyder is offline
post #3 of 15 Old 10-25-2011, 03:17 PM Thread Starter
wxchaser
2014 WK
Nope not that I'm aware of, just wanted to show what the skids looked like installed, especially the fuel tank ones that are a little more difficult to install.
wxchaser is offline
post #4 of 15 Old 10-25-2011, 05:58 PM
rockspyder
So are these ones that you installed yourself?
We are (I think) about to purchase a 2012 Laredo that has the All Weather package. I'm thinking of trying to get/install the skid plates myself.
post #5 of 15 Old 10-26-2011, 04:36 AM
peckmv
Just courious. Do you have to remove the skid plates to change the oil?
peckmv is offline
post #6 of 15 Old 10-26-2011, 04:42 AM
rockspyder
Looks to me that is the oil drin plug through that oval hole in the first picture. But, I could be wrong.
post #7 of 15 Old 10-26-2011, 04:48 AM Thread Starter
wxchaser
2014 WK
That is the oil drain plug in the first pic and no need to remove the skid plate to change oil. They are on to stay.
wxchaser is offline
post #8 of 15 Old 10-26-2011, 08:38 AM
JGCCAYENNE
2012 WK
What is the approximate weight of all the skid plates?
Thanks for the pictures.
JGCCAYENNE is offline
post #9 of 15 Old 10-26-2011, 06:38 PM Thread Starter
wxchaser
2014 WK
They are heavy gauge steel but no idea as to overall weight. You have the front transfer case, front axle skid plate, and the fuel tank skid plates.
wxchaser is offline
post #10 of 15 Old 10-26-2011, 06:44 PM
peckmv
What about the oil filter. Is that accessable with the plates on or is that removed from the top? Thanks in advance.
peckmv is offline
post #11 of 15 Old 10-26-2011, 08:28 PM Thread Starter
wxchaser
2014 WK
From the top, you just take the plastic engine cover off, then remove the cap off the oil canister. Remove the element, using a paper shop towel to avoid a mess, replace with new element and O ring & you are good to go. Drain the oil like you would on any car, with a drain plug.
Canister-free oil filter element prevents landfill, allows incineration; also eases DIY oil changes and prevents ham-fisted oil change places from "holing" or over-tightening the filter.
From the Pentastar engines overview http://www.pentastars.com/engines/tech.php:
"The advanced oil filter system eliminates oil spills, thanks to an incinerable filter element instead of the typical spin-on filters; the filter is conveniently located on top of the engine.
A chain-driven, vane-type variable displacement oil pump adjusts the flow rate and pressure as commanded by the engine management system, which uses a solenoid to drive the pump into low or high pressure mode. For example, below 3,500 rpm, the pump conserves energy by using low pressure; at speeds over 3,500 rpm, the pump switches to high pressure.
A force balance mechanism inside the oil pump adjusts the size of the pumping chambers to alter oil flow. If the oil is cold, the pump reduces the size of the internal chambers. When the oil is hot and thinner, more oil is needed, and a spring increases the size of the pump chambers. This also saves energy.
The pump is driven at a 1:1 drive ratio; its location under the block is more efficient than an on-crankshaft location. An internal, mechanical ball-and-spring relief valve dumps oil into the sump when needed, for conditions such as a cold start with high engine speed. Both pump and pressure regulation solenoid are non-serviceable.
The engine takes six quarts of oil with a filter change. Traditional, non-synthetic motor oil with an ILSAC standard of GF5 is recommended. The standard change interval, with this oil, is 8,000 miles under normal driving conditions. The oil pick-up tube is supported at the windage tray. Three oil gallery plugs are in the engine block; oil pressure an be monitored with a scan tool. Oil pressure and temperature sensors are on the oil filter housing assembly, which is mounted on top, between the heads; the oil cooler (a plate-style coolant to oil heat exchanger) is mounted to the oil filter housing as well. With Wrangler, specific upper and lower oil pan requirements have been engineered into the engine to provide increased grade requirements, keeping the oil within reach of the pump when the vehicle operates at steep angles".
wxchaser is offline
post #12 of 15 Old 10-27-2011, 03:46 AM
peckmv
I have the 5.7 hemi. Is it the same as the V6?
peckmv is offline
post #13 of 15 Old 10-27-2011, 05:00 AM Thread Starter
wxchaser
2014 WK
This should answer your question, and includes some images:
http://wk2jeeps.com/5.7L_6.1L_oil_change.htm
wxchaser is offline
post #14 of 15 Old 10-27-2011, 07:10 AM
Terminator2
5.7 holds 7 quarts not 6.
Terminator2 is offline
post #15 of 15 Old 10-27-2011, 01:06 PM
rockspyder
".... With Wrangler, specific upper and lower oil pan requirements have been engineered into the engine to provide increased grade requirements, keeping the oil within reach of the pump when the vehicle operates at steep angles".
Hmmmm.... not sure I like what the implies about the Grand Cherokee. I mean, yeah, sure, the Wrangler is and likely will always be more of an off-road, rock-crawling machine. But what does this say about the capability of the Grand Cherokee? Admittedly, there is probably 0.001% chance I'm going to end up getting it to a "steep angle," but I would be interested to know what is considered "steep."
Guess I need to go check out that page in detail...
Also, one other thing. "Traditional, non-synthetic motor oil with an ILSAC standard of GF5 is recommended." Anyone know of synthetics being discouraged?
I guess if I could be patient enough to wait until we get ours, all would be explained...
2012 Grand Cherokee Overland or VW Touareg Highline TDI dsfx WK2 Grand Cherokee Forum 39 04-13-2013 08:26 AM
2012 Grand Cherokee buying options? wxchaser WK2 Grand Cherokee Forum 29 09-19-2011 02:59 PM
Pick up my 2012 Jeep Grand Cherokee Overland Thursday Cajun_Mike WK2 Grand Cherokee Forum 13 08-31-2011 10:27 AM
2012 Grand Cherokee Overland/Summit Exterior Changes??? Meat101381 WK2 Grand Cherokee Forum 5 06-20-2011 08:35 AM
New York Auto Show: 2012 Jeep Grand Cherokee SRT8 robbversion1 WK2 Grand Cherokee Forum 37 04-29-2011 04:46 PM
