Side mirrors when going in reverse - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Side mirrors when going in reverse
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-13-2011, 03:11 PM   #1
KuroHouou
I have a brand new 2012 Overland Summit and the mirrors are supposed to tilt down when I put it in reverse. The problem is only the driver side does this.. Are both supposed to tilt down? Anyone know a possible fix. I tried turning the function on and off a few times with no luck. And the passenger side I think is the most important to actually tilt down. I can stick my head out the window to see the driver side
So, are both supposed to tilt down?
KuroHouou is offline   Reply With Quote Quick reply to this message
Unread 10-13-2011, 04:59 PM   #2
KuroHouou
Guess ill answer my own question.
1. Yes it supposed to tilt down both mirrors.
2. I am not sure what I did to fix it but I turned the system on and off a couple more times. Tried adjusting the passenger side down, turning it off then back on. Moved it up and off then back on again. Then all of a sudden it started working. At first it wouldn't put them both back up properly, but I adjusted them to where I wanted them to be when up. Then it lowered and raised them properly. Yeah! Glad I didn't have to take it in.
Unread 10-14-2011, 07:43 AM   #3
BuckeyeWK2
I thought I would love this feature. I turned it off because I thought the mirrors tilted too low.
I am glad you figured it out.
BuckeyeWK2 is offline   Reply With Quote Quick reply to this message
Unread 10-14-2011, 07:51 AM   #4
KuroHouou
I've got some tight parking spots at my apartment and work so it really comes in handy to see the lines in the ground for me. I like the feature, my m3 did it only on the passenger side so I'm glad jeep does it on both sides. Just wish they actually gave us power folding mirrors like the rest of the world gets.. Not a big deal though.
Unread 10-14-2011, 08:30 AM   #5
smonakey
2011 WK
That's not a 2011 option, is it? My mirrors don't do that. Not that it's the end of the world for me. I'm loving that rear camera - don't know how I managed before!
smonakey is offline   Reply With Quote Quick reply to this message
Unread 10-14-2011, 08:34 AM   #6
KuroHouou
Depends on which model you got, I think I read its only on cars with memory seats.. not sure exactly though.
Unread 10-14-2011, 08:45 AM   #7
kmag53
I like to use my mirrors when backing so I turn the feature off. It is handy though for curb parking but otherwise I leave the thing off. Also the backup camera is something that once you get used to it...it is hard to be without. My Wrangler obviously doesn't have that feature which I miss everytime I back it up and don't have a camera.
2012 Jeep Grand Cherokee Laredo E
2011 Chrysler 300 Limited
kmag53 is offline   Reply With Quote Quick reply to this message
Unread 10-18-2011, 05:36 AM   #8
Ungerer
My limited 70th has it ,but I don't like it ;(
Ungerer is offline   Reply With Quote Quick reply to this message
Unread 10-18-2011, 06:37 AM   #9
peckmv
Didn't know this was a feature. Have a 2012 Overland and never noticed either mirror moving when backing. I'll have to check it out this afternoon.
peckmv is offline   Reply With Quote Quick reply to this message
Unread 10-18-2011, 06:53 PM   #10
peckmv
Checked it and neither mirror moves. I guess its not included on the Overland.
Unread 10-18-2011, 07:04 PM   #11
LS1_DOC
Junior Member
You can turn that feature on or off through the evic controls using the steering wheel.
LS1_DOC is offline   Reply With Quote Quick reply to this message
Unread 10-18-2011, 08:49 PM   #12
Ungerer
Is it on all GC keeps
Unread 10-19-2011, 03:35 AM   #13
peckmv
Went through the EVIC and found no mirror function option. Usually the factory has all the features working and the customer turns them on or off. At least that what I thought. I guess its not a feature on mine. Maybe it only on the summit.
Unread 10-19-2011, 04:08 AM   #14
Ungerer
No it is in the features ,I had to turn it on .but I did not like it ! it's with your lights , wipers & door locks lol
Unread 10-19-2011, 04:14 AM   #15
peckmv
I'll check it again. I could have missed it the first time I went through the EVIC. Thanks.
