SERVICE BULLETIN: 23-013-13 2012-2013 WK Noise From Dual Pane Sunroof - JeepForum.com
post #1 of 21 Old 03-22-2013, 08:44 AM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
FYI - ignore if not interested:
SERVICE BULLETIN NUMBER: 23-013-13
GROUP: Body
DATE: March 22, 2013
SUBJECT: Creak Or Click Noise From Dual Pane Sunroof
OVERVIEW:
This bulletin involves inspecting the dual pane sunroof for a potential creak, click or rattle and if necessary, replacing the dual pane sunroof frame assembly.
MODELS:
2012 - 2013 WK Grand Cherokee
NOTE: This bulletin applies to vehicles built prior to November 8, 2012 (MDH
1108XX) equipped with dual pane sunroof (sales code GWJ).
SYMPTOM/CONDITION:
The customer may experience a creak, click or rattle from the dual pane sunroof.
JeepCares is online now
post #2 of 21 Old 03-22-2013, 09:20 AM
mx71
2013 WK
Thank you!
mx71 is offline
post #3 of 21 Old 03-22-2013, 12:19 PM
TAWS600
GROUP: Body
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
I noticed this involves 2012 and 2013 model years but built before Nov 8, 2012. How come 2011 isnt included? I have the same symptoms in my 2011 Limited. It has been at the dealer a couple times for this exact problem. Let me know if 2011 is/can be included so hopefully I can get mine fixed. Thanks!
TAWS600 is offline
post #4 of 21 Old 03-22-2013, 12:46 PM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
I don't know if replacing the dual pane sunroof frame assembly would fix your noise problem. You might want to check with your dealer.
This is the diagnosis portion of the above SERVICE BULLETIN NUMBER: 23-013-13:
DIAGNOSIS:
Push up on the front corner(s) of the fixed pane, then push out (cross-car) on the sunroof
frame at the fixed pane's forward attaching point. Repeat several times.
NOTE: Another way to confirm is to introduce body flex at a very slow speed (idle
speed) while slowly turning right then left. Remove the rear pane’s forward
attachment screw on the side where the noise is heard.
If removing the screw turns off the noise or a creak or click noise is heard, perform the
Repair Procedure.
post #5 of 21 Old 03-22-2013, 02:12 PM
omar0022
2012 WK
interesting that this comes out now... I got my whole frame assembly replaced about 8 months ago, so I'm guessing they were aware of the issue back then. Everything is great now but I notice wind noise more now. I need to take it in to get adjusted.
omar0022 is offline
post #6 of 21 Old 05-08-2013, 05:24 PM
kayoticworld
2012 WK
Can someone who has had this tsb done tell me how long it took the dealership to perform it? I had noticed the creak and rattles not too long after I purchased it. Not overly noticeable, but noticeable nonetheless with the radio off. I saw this tsb come out on this forum about a month ago but decided I would just wait until I took it in for its first oil change. I was under the impression this was an half a day job once they had the part. The dealership has had my jeep for 5 days now. I don't want to rush them because I want it done right the first time. But it just don't seem like it should be taking this long either as the service advisor seem to think it would only be half a day to maybe 1 day. I should also mention this is a brand new dealership that has opened about a month ago. I say that because I don't know how experienced they are with this issue. Maybe I'm wrong. I did talk them into getting me a courtesy car for the inconvenience yesterday.(Chrysler 300m)
2012 Grand Cherokee Overland 5.7L V8 - Bright Silver with New Saddle Interior
kayoticworld is offline
post #7 of 21 Old 06-12-2013, 11:20 PM
tarobapp
2014 WK
I had the rattling and the dealer replaced the frame around the sunroof. It actually took the dealer about 6 hours to fix, I believe. They didn't have the part, so they ordered it, then I came back two days later, and they took half the day to fix.
tarobapp is offline
post #8 of 21 Old 06-13-2013, 07:24 AM
EmileN
2011 WK
Interesting that this is 2012-2013 models. Does this imply that something about the sunroof design was changed in 2012 that's causing an issue?
EmileN is offline
post #9 of 21 Old 06-13-2013, 10:33 AM
txwest
2012 WK
I have a rattle on mine also. Just rolled over 36k. Wonder if I could just insert some foam tape in between the rails or if it is an actual issue with the frame.
Sent from my S-III using JeepForum
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline
post #10 of 21 Old 06-13-2013, 04:19 PM
13ovsummit
2013 WK
On my 2013 the sun-roof is quiet. How does one decode the VIN to find build date?
Rob
13ovsummit is offline
post #11 of 21 Old 06-13-2013, 05:55 PM
kayoticworld
2012 WK
Rob
You don't need to decode the Vin to find out the build date. Just open your drivers side door and look for the Chrysler sticker on the door itself. Your build month and year should be on that sticker. If your sunroof is not making any noise then I wouldn't bother with it. Hell mines was making a slight noise and I wish I had never let the dealership touch my vehicle. They have created more problems then its worth. Can you go to another dealership to have that dealership fix the problems the other one caused doing warranty work? At this point I want nothing more to do with my current dealership, but I feel they should fix the problems they have caused. Take it for me if its not making a noise or nagging at you......don't fix what is not broken! I do still love my jeep though.....
post #12 of 21 Old 06-13-2013, 08:39 PM
13ovsummit
2013 WK
^^^ - Thanks kayotic! Duh - I shoulda known that. I'm not gonna let the dealer touch it. I wanted to know if my build date was before or after the one mentioned in the SB, in case problems pop up later.
Yeah, I agree - finding a decent dealer/service dept. is a real chore lately. They seem to keep their reputations well hidden for the most part, and it's up to us customers to try, and try again until we find a good one. Good luck ... !
Rob
post #13 of 21 Old 07-15-2013, 03:24 PM
Eric_R
2012 WK
Does this fix a rattle with the forward section of the sunroof? I have a rattle near the front left corner (right above my head). Ugh!
If I put a little upward pressure on that corner of the glass, the rattle stops.
I'm guessing this is something that I need to coordinate with my dealer to get fixed, right?
Eric_R is offline
post #14 of 21 Old 07-16-2013, 01:04 PM
kayoticworld
2012 WK
Yes, something you should definitely coordinate with the dealership. They will more than likely have to order the assembly. I would also ask the dealership is this something they have experience fixing. I don't believe the dealership I took it to had any experience with it and something that should of taken about 1/2 day to one full day took a total of 8days. Then again they may have just pushed my warranty issue to the side.........
post #15 of 21 Old 08-31-2013, 11:18 AM
Eric_R
2012 WK
Rattle fixed!
Just to update -
My sunroof rattle is fixed! Yea!
According to the dealer, it was a loose mounting bolt near the front left corner. He said, after finding the loose bolt, they dropped the headliner to check the other bolts. There was also a loose bolt somewhere on the passenger side. They checked all the mounting bolts, reinstalled the headliner and the rattle is gone. Hopefully it doesn't come back.
I was really worried that this was going to be a big job, they would have to order parts, etc... What a relief!
Eric
Eric_R is offline
