Service Bulletin 21-006-13 '09-'12 WK/'09-'10 XK 5.7L FLASH: Transmission - JeepForum.com
post #1 of 45 Old 07-25-2013, 06:56 AM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
fyi-
Service Bulletin NUMBER: 21-006-13
GROUP: Transmission and Transfer Case
DATE: July 25, 2013
SUBJECT:
Flash: Transmission Performance Enhancements
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control Module (PCM) with new software.
MODELS:
2009 - 2012 (WK) Grand Cherokee
2009 - 2010 (WH) Grand Cherokee (International)
2009 - 2010 (XK) Commander
2009 - 2010 (XH) Commander (International)
NOTE: This bulletin applies to vehicles equipped with a 5.7L engine (sales code EZH).
SYMPTOM/CONDITION:
A small number of customers may experience any of the following:
∑ Erratic or inconsistent initial 2-3 upshift(3-4 upshift on 2012 MY vehicles)
∑ Sluggish performance during low speed/rolling stop maneuvers(2012 MY vehicles only)
Transmission Enhancements are also included with this software release. These changes include the following:
∑ Enhanced torque converter lock-up schedule to reduce transmission operating temperatures(2009 MY vehicles only)
JeepCares is online now
post #2 of 45 Old 07-25-2013, 07:40 AM
FranksWK
2005 WK
Thanks!!
FranksWK is offline
post #3 of 45 Old 07-27-2013, 11:50 AM
RichWK2
2012 WK
2012 MY Vehicles
JeepCares,
What does "2012 MY Vehicles" signify? Near the end of the optional equipment list for my Jeep lists "MY:2012", so I assume this TSB applies to my 2012 Hemi WK2, but I'd like to know what it stands for.
Thanks
RichWK2 is offline
post #4 of 45 Old 07-27-2013, 09:04 PM
Wk2downunder
2011 WK
MY2012 = model year 2012
Wk2downunder is offline
post #5 of 45 Old 07-28-2013, 07:14 AM
RichWK2
2012 WK
My 2012
Thanks, I feel pretty stupid, but I'll get over it
RichWK2 is offline
post #6 of 45 Old 07-28-2013, 04:44 PM
EmileN
2011 WK
Hmm...Is this one of those "if it ain't broke..." I wonder if there are any improvements to take advantage of if i'm not having any issues otherwise..
2011 Overland Hemi
EmileN is offline
post #7 of 45 Old 07-28-2013, 11:25 PM
xjrguy
My 2012 is definitely exhibiting the symptoms of this TSB.
I am going to get this one done at my local dealer this week and report back.
When my vehicle is driven around a corner (slow for turn at light, make turn, then accelerate out) the vehicle doesn't seem to know what gear it should be in for proper acceleration.
I make a right turn heading home every day from work.
Prior to making this turn, I am driving approximately 40 to 45mph. To make the turn, I slow to around 20-25 MPH and once straight I hit the gas and all I hear is motor with minimal acceleration. Vehicle feels like it is in 4th gear when it should be in 2nd.
Hoping this fixes the problem as it's very annoying and also happens when slowing for a red light that suddenly turns green, try to accelerate and it seems I am in too high of a gear.
xjrguy is offline
post #8 of 45 Old 07-29-2013, 12:58 PM
LibGrandCher
2012 WK
Please post on wether this TSB helps your shudder issue.
I won't be going in for a few weeks.
Thanks in advance
LibGrandCher is offline
post #9 of 45 Old 07-29-2013, 02:18 PM
Tieva
2012 WK
Is this Bulletin the answer to Star Case S1118000038 and the Fish Bite issue?
Tieva is offline
post #10 of 45 Old 07-30-2013, 11:34 PM
xjrguy
Thanks in advance
To clarify, my WK2 doesn't have shudder or fish bite with the driveline.
The problem I am hoping the TSB fixes is the fact the vehicle has no idea what gear it's supposed to be in when accelerating after braking for a light or after making a turn.
Vehicle goes in Thursday so I should know after a drive cycle.
xjrguy is offline
post #11 of 45 Old 07-31-2013, 11:56 AM
Tieva
2012 WK
Has anyone here on the forum had the new PCM update done? If so, did you notice a difference in the shift performance between the 3 & 4 gears. Did the tugging (fish biting) go away?
Tieva is offline
post #12 of 45 Old 07-31-2013, 01:12 PM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
The fishbite one isn't out yet.
post #13 of 45 Old 08-01-2013, 10:02 AM
Tieva
2012 WK
Thanks Lee. But this TSB will fix the "seems like it's missing a gear" when you accelerate issue??
Tieva is offline
post #14 of 45 Old 08-01-2013, 12:05 PM
xjrguy
Ok, I just got the update done. My local dealer is AWESOME. In and out in 20 minutes.
I brought the TSB in and like the last time I had updates I asked them to perform the TSB and got no pushback.
Here is the work order text:
AUTO TRANSMISSION - AS PER TSB ATTACHED TO REPAIR ORDER SOFTWARE UPDATE AVAILABLE FOR VEHICLE CHECK AND PERFORM UPDATE IF APPLICABLE
Software issues/updates found for PCM and ASCM/updated as requested by the customer.
Performed software updates on the PCM and the ASCM, installed required label, reset all trouble codes associated with procedure, old PCM software #68111691ae new #68111691af, old ASCM software #56029558ae new #56029558ai
My WK2 was last updated with the most recent software builds for the entire vehicle back on May 6.
You can see that Jeep has had a couple updates to the ASCM in between May 2013 and present day (August 1) as the build jumps from ae to ai.
My work is only a couple miles from the Jeep dealer so I can't honestly report back on if the issues I had are fixed or not but I will once I get some drive time with the new software build loaded with this TSB.
FWIW my Jeep is a 2012 WK2 Summit with the HEMI.
xjrguy is offline
post #15 of 45 Old 08-01-2013, 06:55 PM
xjrguy
Ok wow
Ok I am out on a drive now on roads here in SoCal I drive every day.
All I can say is run don't walk to your dealer and get this TSB done if you have a 2012 WK2 with a V8.
If you ever had power train complaints before, this update fixes them!
More details when I get back home and can post from my computer vs phone.
Was so impressed I had to pull off the side of the road to update you guys.
More feedback after I return from my cruise on PCH.
xjrguy is offline
