Service Bulletin 09-001-12 Engine Oil Consumption Guideline 2012-2013 - Page 2 - JeepForum.com
post #16 of 22 Old 02-12-2013, 05:37 PM
LouC
2007 WK
Interesting information, and I'd say it's in line with most of the vehicles I have had over 40 years of driving. The majority of the have used about a qt between changes (3-4k miles).
We had a Toyota (89 Corolla GTS) that used none, an 88 Camry that smoked on cold starts (valve seals) and a 98 Subaru that leaked like crazy (way more that evev the 4.0 in my 98ZJ) till we had all the leaks fixed when we had the head gaskets done.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #17 of 22 Old 02-12-2013, 06:37 PM
90grandoneer
90grandoneer's Avatar
2006 WK
JeepCares, this is all good "guideline" info., and keep up the good work posting this type info. IMO, excessive oil consumption, in many cases (in addition to your service bulletin) can be traced back to the initial break-in of the engine. If it's driven like "granny" during the break-in period, you're more likely to have an increase in oil consumption later on. Today's engine assembly tolerances are much tighter than in the "old days", but a good varied RPM break-in will still, in most cases, result in less oil consumption over the long run. I bought my Hemi Magnum new and broke it in as indicated above and it doesn't burn a drop between 6000 mile changes. I don't know how my Hemi WK was broken in, but it uses a little (maybe 1/2 qt) between 6000 mile changes.I do get some through the PCV Valves and into the catch cans in both though, but it is minimal. I'll be doing an experiment soon, by adding a second in-line PCV valve to see if it will, (1) work properly and (2) reduce valve oil bypass. This will be an effort to correct the lousy stock PCV system in the Hemi's.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #18 of 22 Old 02-13-2013, 10:19 AM
jim_in_PA
2012 WK
This specification certainly doesn't make me happy, but thanks to Costco, I have six quarts of Mobile 1 out in the garage for $26 (total) to insure I have oil to top off when some gets used. I did need to top off with a quart in the first 4K miles, but haven't used any perceptibly since my 8K oil change...at just over 12K right now.
• 2012 JGC Summit Hemi
• 2016 Subaru Outback Limited
• 2011 Subaru Outback Limited
jim_in_PA is offline
post #19 of 22 Old 02-13-2013, 11:13 AM
MickinNY
2013 WK
Originally Posted by BMRisko View Post
My 2004 Tahoe w/ the 5.3L and 190,000 miles uses less than 1 qt over oil change intervals of ~6k miles.
My 5.7L WK2 used almost 2 qts over 6,000 miles and it only has 7200 miles on the odometer. I guess it seems high given the extremely low to non-existent consumption with my other vehicles. No one else things that 1 qt over 750 miles sounds incredibly high? With the recommended 8,000 mile oil change, that could be as much as 17 qts per oil change interval!
Down 1 quart every 750 miles? That sure sounds high to me. I wouldn't be too pleased with that.
I've experienced very little (or none at all) oil consumption in any of my vehicles over the years. This is a relevant topic for me because I did notice I was down a quart in my 2013 V6 WK2 at 1000 miles, which surprised me. Checked for leaks & couldn't find any. I'm at about 1800 now & so far it doesn't need to be topped off again. But I'll certainly be keeping a close eye on it.
MickinNY is offline
post #20 of 22 Old 03-02-2015, 11:24 AM
lastontheboat
2013 MK Patriot
Found a table spoon of oil under my 2013 Patriot (2.4L 16,000 miles) yesterday. Jeep is currently sitting at the dealership awaiting an oil leak test. I had no idea that loosing 25% of your oil capacity every 2k miles would be acceptable. I have a 1998 Saturn that doesn't burn a quart every 3K.
lastontheboat is offline
post #21 of 22 Old 03-07-2015, 07:33 AM
lastontheboat
2013 MK Patriot
Dealership found i was leaking from the oil pan. They dropped it, replaced the gasket and was on my way. Still no fix for the squeak when I back up. But I was very happy they fixed my oil leak.
post #22 of 22 Old 03-09-2015, 03:04 PM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
Glad to hear your oil leak issue has been resolved! If you’d like me to look into the noise you’re experiencing when backing up, please message me your VIN.
JeepCares is online now
FYI - Service Bulletin 26-004-12 - 2011-2012 Fluid Flushing Requirements JeepCares WK2 Grand Cherokee Forum 16 06-08-2012 09:18 AM
2011 (WK) Grand Cherokee (International Markets) - Service Bulletin 26-002-12 JeepCares WK2 Grand Cherokee Forum 0 03-16-2012 09:16 AM
2012 now or 2013 next year Should i wait? rockit WK2 Grand Cherokee Forum 23 01-11-2012 08:51 PM
GC 2012 Factory Service Manual Schnappi WK2 Grand Cherokee Forum 6 11-29-2011 03:46 PM
will 2012 SRT8 options come to 2013+ models? PLD7 WK2 Grand Cherokee Forum 1 05-21-2011 01:09 PM
