Selec-Terrain Questions - JeepForum.com
post #1 of 5 Old 12-13-2010, 07:28 PM Thread Starter
jeepsterguy
2011 WK
I read the manual and I think I understand the system.
I would like to make sure that I got it right.
For the following settings only: Sport, Snow, Auto, Sand, I can shift to and from these positions at any speed and any road surface.
If I am driving in snow and the selector is on SNOW and I find myself on clear, dry, asphalt I don't have to shift to Auto if I don't want to. It will not stress the 4x4 system. Is that correct?
I am transitioning from part-time/full-time Jeeps to the new stuff and I would like to make sure.
jeepsterguy is offline
post #2 of 5 Old 12-14-2010, 09:33 AM
mr2guru
This is your daddy.
http://www.jeep.com/vehiclequicktips
All the information is there.
In short, yes you can move the dial around to your heart's content. But.... "Rock" will only engage that calibration when you are in 4Low and that requires specific seperate engagement procedures. Sport, Auto, Snow, and Sand/Mud can be engaged at any speed.
mr2guru is offline
post #3 of 5 Old 12-14-2010, 10:35 AM
wjs81866
wjs81866's Avatar
2011
Snow mode puts 50/50 torque split, Auto is 52/48? rear to front
1) 2011 Grand Cherokee LImited
Blackberry Pearl
5.7L
Quadra Trac 2
Lux Group 2
20" tires and rims
Towing package
2) 2011 Grand Cherokee Laredo X
Blackberry Pearl
5.7L
Quadra Drive 2
Quadra Lift
Laredo X Group 25 package
Chrome Fogs and Mirrors
Off-Road Adventure II Package
P265/60R18 Michelin LTX M/S 2's
BWoody 4" Velocity Intake
wjs81866 is offline
post #4 of 5 Old 12-14-2010, 02:31 PM
john3r
2011 WK
Also it is important to remember if your in heavy snow and want to engage 4wd Low:
With the vehicle at speeds of 0 to 3 mph (0 to 5 km/h), the ignition switch in the ON/RUN position or the engine running, shift the transmission into NEUTRAL, and press the “4WD LOW” button once on the transfer case switch. The “4WD LOW” indicator light in the instrument cluster will begin to flash and remain on solid when the shift is complete
When operating your vehicle in 4WD LOW, the engine speed is approximately three times that of the 4WD HI position at a given road speed. Take care not to overspeed the engine and do not exceed 25 mph (40 km/h).
(taken from the Quick Tips)
Also, would recommend downloading the Jeep Grand Cherokee iPhone App. It's a no-brainer if you own a WK2 and iPhone.
All of these kind of notes, and etc are easily available if you need them.
john3r is offline
post #5 of 5 Old 12-14-2010, 04:31 PM Thread Starter
jeepsterguy
2011 WK
Due to lack of information, for some time I assumed that the MP3023 TC had some kind of an internal differential for normal 4x4 with a clutch to control slippage.
I finally got my hands on the schematics of the MP3023 (as used in GM trucks) and I can see that there is no differential and that all the 4x4 biasing is a matter of force applied on a wet clutch. It seems that the clutch is always active and slipping to one degree or another to achieve the proper bias according to what is dialed in, controlled by inputs such as vehicle speed and/or wheel speed.
Questions for Current Owners... Snipe315 WK2 Grand Cherokee Forum 6 09-27-2010 03:24 PM
