Seeking Final QTI/QTII Advice To Narrow Down 2011-2013 Search - Page 3 - JeepForum.com
post #31 of 41 Old 02-14-2014, 06:52 PM
Kev M
2012 WK
Originally Posted by ColdCase View Post
Not that simple. QTII will lock front and rear axles without BTC before any wheel spins, so its marginally better for starting out in snow mode or for stoplight to stoplight racing. Unlike mud, you don't really want to spin on snow, ice, or dry pavement. So the QTII traction response is quicker and better, other things being equal like tires. Whether you need the extra performance is subjective. When you have all wheels spinning wildly, the type of transfer case probably doesn't make much difference
The biggest QTII advantage for everyday use, I think, is the several operating modes tailored to mud, snow, sport... etc. ... and the you can add QD.
Hmmm, I wasn't aware our QTII system had any differential locking ability...
Kev M is offline
post #32 of 41 Old 02-14-2014, 09:08 PM
loveracing1988
Using the abs system it fakes it.
loveracing1988 is online now
post #33 of 41 Old 02-14-2014, 09:55 PM
Kev M
2012 WK
That's what I was explaining, but he made it sound like something different.
He doesn't mean the QT I doesn't use that system too, does he?
Kev M is offline
post #34 of 41 Old 02-14-2014, 10:45 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Perhaps jeep now using the term "brake differential lock" to mean what many of us call "brake traction control" has been confusing. The WK2 brake differential lock provides a similar function as a diff lock by locking (braking) one half of the axle. The WK2 diff lock locks both half axles together within the diff housing with a clutch. Diff locks are much more efficient than brake locks and can be "preloaded". Brake locks must have wheel spin first to activate, but modern computers are pretty quick.
QTI is entirely traction computer controlled brake traction control with a fully open transfer case (no lock). QTI is very effective, many here wheel with it.
QTII uses brake traction control and a variable lock transfer case. The transfer case lock is under computer control and is variable from 0 (fully open) to 100%. The transfer case also has a low range (always 100% locked in low).
QDII uses brake traction control only on the front axle. A locking diff is used on the rear axle as well as the QTII locking transfer case. Transfer case and rear diff lock are controlled by the traction computer and varies from 0 to 100%. The transfer case also has a low range (always 100% locked in low).
The newer SRTs have the QDII system without the low range.
The traction computer manipulates locks and brakes based on several inputs ranging from throttle open/close rate, steering angle, and wheel speed sensors to the position of the select terrain switch. The SRT launch control locks up the transfer case and rear diff to get all available engine power to the ground on launch. Same thing happens when you mash the throttle on a QD equipped vehicle in the normal select terrain mode, .
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #35 of 41 Old 02-14-2014, 10:51 PM
Kev M
2012 WK
Ok, so, there's no side-to-side locking difference between the QT I & II.
So, how's that different from what I said?
Not being argumentative, just trying to understand any actual differences.
Kev M is offline
post #36 of 41 Old 02-14-2014, 10:57 PM
Kev M
2012 WK
Ok, re-reading the threa. Are you saying that it's an electronic control issue?
i.e. that QT II is programmed to deal with wheel spin sooner/better/faster.
Kev M is offline
post #37 of 41 Old 02-14-2014, 11:28 PM
ColdCase
ColdCase's Avatar
2011 WK
I think you said QTI and QTII rely on brake traction control. I was just saying thats perhaps too general a statement that's not true in every situation.
You can look at it as QTII doesn't rely entirely on brake traction control. It will first lock the transfer case, sometimes pre-emptively, and then augments with brake traction control if necessary. In a marginal situation, a QTI system may start spinning a tire where a QTII system doesn't.
When all the tires are spinning, both QTI and QTII are using brake traction control.
ColdCase is offline
post #38 of 41 Old 02-14-2014, 11:36 PM
ColdCase
ColdCase's Avatar
2011 WK
Ok, re-reading the thread. Are you saying that it's an electronic control issue?
Other things being equal, QTI will spin a tire in many marginal situations where QTII does not. Its not so much programing but more the nature of open vs locked transfer cases.
Another example is the program can lock the QTII transfer case in anticipation of wheel spin such as when you mash the throttle. This can prevent wheel spin in the first place. The brake traction control computer, however, needs to determine which of the four tires are spinning before it can react.
Keeping tires from losing traction and spinning in the first place is a big help. Dunno if you get a chance to drive something that has brake traction control and a manually open/locked transfer case. On slippery streets and an open transfer case, the brake traction control always seems to be working. With the transfer case locked, its rare to hear the brake traction control work.
How much marginally better QTII or QDII is over QTI for you depends on how you use your vehicle. For many, the marginal utility is not worth the cost. You can certainly get by nicely without.
ColdCase is offline
post #39 of 41 Old 02-21-2014, 12:49 PM
marko138
2011 WK
Jiffster,
I'm in the exact same boat as you. I'm currently looking for a WK2 (to replace my WK). I'm also debating on the QT2. My WK has the QT1 and I've only gotten stuck once in 7 years, and I don't do any real wheeling, so I certainly don't need the QT2. But I'm looking anyway.
marko138 is offline
post #40 of 41 Old 02-22-2014, 12:09 AM
ChrisCicc
You DEFINITELY don't need it for snow or the boat, and I honestly don't think you'll need it for hunting or camping either.
Though have used the dial to select SNOW, or SAND for appropriate conditions, I've still not used the low range. Oh wait, I did use the low range ONCE, when I was pulling a high-centered Jeep Wrangler Unlimited off a sand dune. That was it, and honestly, it came off so easily with a little tug that I probably didn't need it for that.
Yeah, I enjoy having it, but from your description I'd say you probably don't need it.
EDIT - I've launched many boats with multiple tow vehicles (mostly Jeeps) and NEVER used or needed low range for it.
I used 4 low in both sand and snow plenty of times over the years with my '99 V8. You don't need 4 low to launch from a ramp, but launching from beaches is a whole other story, so it's up to your use.
I routinely needed 4 low to pull a boat from a beach ramp in sand. I also used 4 low to pull a F-150 that was pulling a boat that had it's electronic 4wd system fail
In snow (granted this was before the time of the "snow dial"), I used 4 low to negotiate the hills in my area when they were un-plowed. If you live in a flat area you may not need it. Just my 2 cents, opinions may vary
Edit: I just upgraded to a '14 limited, and the one option I got was the Off Road Adventure II package, so I will be putting the new snow and sand modes to the test first chance I can!
ChrisCicc is offline
post #41 of 41 Old 02-22-2014, 07:28 AM
2k2wranglerx
If you're going to go off road. Make sure you have a low range.
It's not about torque. It's about control.
Our anniversary doesn't have a low range. That said. I never plan on going near a trail. Our limited wk had qd2 and it was unbelievable when pushed. Blizzard of 09? I think it was. I used it to go recover a few stuck rigs in 18" of snow. Both diffs locking got it done. Low range is a huge help when recovering too.
That said. The wk2 I have uses the same esp that my jks did. It allows ample wheel spin in the snow while using the brakes to act as a limited slip. And I'm very very happy with it. Jeep really has that down. I don't have to turn the esp off to make snowy climbs like in the ford (that all but cuts the power).
93 yj. 355 chevy, heads, cam, intake, etc. 35's, bumpers, winch, lights, and a killer stereo.
2k2wranglerx is offline
