Seat memory & key fobs? - JeepForum.com
post #1 of 16 Old 02-28-2014, 09:20 PM Thread Starter
danbrew
2014 WK
We bought a 14 GC Limited about a month ago. It's my wife's car and she drives it 98% of the time. I've programmed the seats & mirrors into memory position 1 & 2. I wonder if there is a way to get the seats to move to the stored position if I unlock or if use the near field function to open the door. The way it works now is that I have to open the door and then press the #1 or #2 memory position. I'm a big guy and my wife is a small gal. A small nit, I know, but it take a few moments for the seat to adjust. I'd like to save those small few moments and have it begin to adjust if I use my fob.
Any pointers appreciated.
danbrew
danbrew is offline
post #2 of 16 Old 02-28-2014, 09:27 PM
MattXJ
2014 WK
Yeah, there's a procedure in the user manual to link a key fob to a specific memory position.
89 XJ (Ltd): RE 3.5", full leafs, 3/4" coil spacers, RE monotubes, JKS Adj trac, tcase drop, OME steering stab., BFG AT 31x10.5xR15s on 15x8 3.75bs, Borla cat-back
14 WK2 SRT: DiabloSport catch can, Borla S-Type
MattXJ is offline
post #3 of 16 Old 02-28-2014, 09:44 PM
MattXJ
2014 WK
Customer Programmable Features — Uconnect®
5.0/8.4 Settings
Press the Apps soft-key, then press the Settings soft-key
to display the menu setting screen. In this mode the
Uconnect® system allows you to access programmable
features that may be equipped such as Display, Clock,
Safety/Assistance, Lights, Doors & Locks, Auto-On
Comfort & Remote Start, Engine Off Operation, Compass
Settings, Audio, Phone/Bluetooth and SiriusXM Setup.
NOTE: Only one touchscreen area may be selected at a
time.
When making a selection, press the soft-key to enter the
desired mode. Once in the desired mode press and
release the preferred setting until a check-mark appears
326 UNDERSTANDING YOUR INSTRUMENT PANEL
next to the setting, showing that setting has been selected.
Once the setting is complete either press the Back
Arrow soft-key or the Back hard-key to return to the
previous menu or press the X soft-key to close out of the
settings screen. Pressing the Up or Down Arrow soft-keys
on the right side of the screen will allow you to toggle up
or down through the available settings.
Doors & Locks
After pressing the Doors & Locks soft-key the following
settings will be available.
Memory To FOB — If Equipped
This feature provides automatic driver seat positioning to
enhance driver mobility when entering and exiting the
vehicle. To make your selection, touch the Memory
Linked To FOB soft-key, until a check-mark appears next
to setting, showing that setting has been selected. Touch
the back arrow soft-key to return to the previous menu.
NOTE: The seat will return to the memorized seat
location (if Recall Memory with Remote Key Unlock is set
to ON) when the Remote Keyless Entry (RKE) transmitter
is used to unlock the door. Refer to “Driver Memory
Seat” in “Understanding The Features Of Your Vehicle”
for further information.
Linking And Unlinking The Remote Keyless Entry
Transmitter To Memory
Your RKE transmitters can be programmed to recall one
of two pre-programmed memory profiles by pressing the
UNLOCK button on the RKE transmitter.
NOTE: Before programming your RKE transmitters you
must select the “Memory To FOB” feature through the
Uconnect® system screen. Refer to “Customer- Programmable
Features — Uconnect® Access 8.4 Settings ” in
“Understanding Your Instrument Panel” for further information.
To program your RKE transmitters, perform the following:
1. Remove the Key Fob from the ignition (or change the
ignition to OFF, for vehicles equipped with Keyless
Enter-N-Go).
2. Select desired memory profile (1) or (2).
NOTE: If a memory profile has not already been set,
refer to Programming The Memory Feature for instructions
on how to set a memory profile.
166 UNDERSTANDING THE FEATURES OF YOUR VEHICLE
3. Once the profile has been recalled, press and release
the SET (S) button on the memory switch, then press
and release button (1) or (2) accordingly. “Memory
Profile Set” (1 or 2) will display in the instrument
cluster on vehicles equipped with the EVIC.
4. Press and release the LOCK button on the RKE
transmitter within 10 seconds.
NOTE: Your RKE transmitters can be unlinked to your
memory settings by following steps 1-4 above and pressing
the UNLOCK button (instead of LOCK) on the RKE
transmitter in Step 4.
MattXJ is offline
post #4 of 16 Old 03-01-2014, 10:53 PM
DRKRED12
As many have said before " The Owners Manual Is Your Best Friend".
DRKRED12 is offline
post #5 of 16 Old 03-02-2014, 08:45 AM
Ken-G
2014 WK
The problem is you have to use unlock on your FOB and not the keyless entry for this to work.
Ken-G is offline
post #6 of 16 Old 03-02-2014, 12:22 PM
Kev M
2012 WK
Are you sure? That's not the case on our 2012.
Kev M is offline
post #7 of 16 Old 03-02-2014, 12:33 PM
dcipher
2014 WK
I can confirm that it works fine with keyless entry - i have both fobs setup that way.
dcipher is offline
post #8 of 16 Old 03-02-2014, 02:46 PM Thread Starter
danbrew
2014 WK
Thanks all!
danbrew is offline
post #9 of 16 Old 03-02-2014, 03:30 PM
b3conswj
Definitely not the case with my 2014 Limited. With the fob in my pocket, I unlock the door by touching the door handle and the memory setting ballet begins.
b3conswj is offline
post #10 of 16 Old 03-02-2014, 08:44 PM
MattXJ
2014 WK
Now here's a question though, once you've got this setup. Say you're out for a drive and you make a few adjustments to your seat etc., then simply turn the truck off and hop out. While you're gone the wife goes for a drive with her FOB. Next time you come back with your FOB, does the seat go back to the position you last left it, or the position last explicitly stored in the Memory position associated with your FOB?
Basically when I make minor adjustments to my seat etc., will I need to explicitly re-store memory position 1 before getting out?
MattXJ is offline
post #11 of 16 Old 03-03-2014, 04:32 AM
jrhillma
2011 WK
Originally Posted by MattXJ View Post
Now here's a question though, once you've got this setup. Say you're out for a drive and you make a few adjustments to your seat etc., then simply turn the truck off and hop out. While you're gone the wife goes for a drive with her FOB. Next time you come back with your FOB, does the seat go back to the position you last left it, or the position last explicitly stored in the Memory position associated with your FOB? Basically when I make minor adjustments to my seat etc., will I need to explicitly re-store memory position 1 before getting out?
I'm pretty sure that I've made minor adjustments while going down the road and just hit "S" followed by "1" to store them in my profile. No need to hit "Lock" on the RKE again. The "Lock" on the RKE is what pairs an individual fob with a given profile setting in the memory. Once it's paired, I think as long as you remember to store ("S") the new settings in the car, they'll be remembered when you next get in the car.
One of the things that surprised me about my '11 Overland is that I *can* store setting changes while in motion. In my Magnum it gives an error message that the settings aren't available, unless you're at a stand still and in Park or Neutral. I always thought that was dumb.
jrhillma is offline
post #12 of 16 Old 03-03-2014, 05:27 AM
Kev M
2012 WK
But yes, you do need to specifically store minor adjustments.
Oh, and to that end, IF the memory system burps and leaves your wife's Sirius stations disolayed you can press the appropriate number on the door to change to your settings (if you're stopped, in Park), BUT be careful not to accidentally hit the S button first, or you may be manually reprogramming all your stations....ask how I know lol.
Kev M is offline
post #13 of 16 Old 03-03-2014, 05:28 AM
dcipher
2014 WK
Actually - I have found that slight adjustments do require me to store in memory AND store to fob again. My wife found the same thing...
dcipher is offline
post #14 of 16 Old 03-03-2014, 06:27 AM
Ken-G
2014 WK
Defiantly not the case with my 2014 Summit, I have the FOB in the pocket and use keyless and nothing. If I push the button it works correctly.
Ken-G is offline
post #15 of 16 Old 03-03-2014, 06:31 AM
dcipher
2014 WK
Pushing the unlock button on the key fob works, but keyless entry does not? That's really strange...
dcipher is offline
