Sand and QTI - QTII all wheel drive - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Sand and QTI - QTII all wheel drive
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi50" SINGLE ROW PANDEMIC LED Light bar FEATURES 4D Opt
Unread 06-23-2015, 09:06 PM   #1
nha11
Question Sand and QTI - QTII all wheel drive
Hello,
New member here. I am looking to purchase a used Grand Cherokee and am trying to decide between a Laredo and a Limited. One thing I am concerned about is the 4WD system on each.
I found this excellent post about the three different 4WD systems. Excellent info, I've been reading a rereading.
It seems that the Quadra-Trac I in the Laredo will be great for the winter snow. However, I also plan to use the GC for drive on beaches on the Eastern Shore. From other drivers experience, do you think the QTII system is necessary for driving on sand as it allows for the finer control?
I figured if I can't try it myself, the next best thing would be to ask other drivers.
Thanks for your time.
nha11 is offline   Reply With Quote Quick reply to this message
Unread 06-23-2015, 10:30 PM   #2
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
On hard pack, probably not much difference, but on softer stuff you want to keep the momentum going and the QTII sand traction mode helps do that (its not 4Low). QTI will depend entirely on brake traction control.
I don't have a lot of experience, but some here drive routinely on beaches and should jump in here with advice within a day or so.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 06-24-2015, 07:02 AM   #3
nha11
Thanks, ColdCase. That's along the lines I was thinking. The beach is usually packed but sometimes (and in some places) it's not. I know deflating the tires will assist but perhaps I'll also want the control of the QTII system.
I actually prefer the asthetics of the Laredo to the Limited (of the two particular vehicles I am considering). Just want to make sure I've considered everything.
Thanks
Unread 06-24-2015, 07:20 AM   #4
loveracing1988
They do make the Laredo with the cold weather group or the off road group, both of which would include qt2. I've never driven the qt1 system on sand, but right after we first got my wife's jeep I took it in some sand that was much looser than I expected. I wasn't going anywhere in auto, switched to sand and backed right out like it was nothing. Granted I might have been able to do the same in auto with the TCS shut off, but sand mode impressed me quite a bit with that.
loveracing1988 is offline   Reply With Quote Quick reply to this message
Unread 06-24-2015, 09:42 AM   #5
kryogen
2011 WK
Quadra drive is unstoppable....
I would personally get at least QT2 if you plan to get in deep sand or snow.
kryogen is offline   Reply With Quote Quick reply to this message
Unread 06-24-2015, 01:07 PM   #6
marko138
2011 WK
I had my QT1 equipped Laredo X on the beach in North Carolina last week. It had absolutely zero issues. In fact, it was much better in the sand than my 2005 WK with QT1. Zero issues. I was also at 20psi.
This is Sound side...which is much easier going than ocean side....but I had no trouble in very fine and very deep sand on ocean side.
marko138 is offline   Reply With Quote Quick reply to this message
Unread 06-24-2015, 01:30 PM   #7
peckmv
Unless your going to go in some really soft sand or on the dunes all you really need is 2wd. The most important thing is to air down to 15-20 psi. I went on Assateague Island many times with just 2wd with no problems. They don't allow you in the dunes there and if you stay in the tracks you'll be fine. I do recommend you have a shovel, board, and a good jack. On Assateague these things are required. Then don't forget to wash your truck down including the undercarrage and brakes. Sand gets into everything, and I mean everything.
peckmv is offline   Reply With Quote Quick reply to this message
Unread 06-24-2015, 03:46 PM   #8
nha11
Assateague is exactly where I am planning to take this. Good to know that I wouldn't have any issues. Thanks for the response.
Unread 06-24-2015, 05:22 PM   #9
peckmv
You will need a ORV permit also. Here's a link with all the info you'll need. Have fun.
http://www.nps.gov/asis/planyourvisit/osv.htm
