RRO WK2 Winch and bumper kit - Page 7 - JeepForum.com
post #91 of 117 Old 04-14-2013, 08:31 AM
JMP8562
89 lifted wrangler to 95 lifted cherokee to 01 GC now 07 JK 4 DOOR X WITH HIGH ROCK FRONT WINCH BUMPER APPROACH ROLLERS/WARN 9.5TI WINCH WITH UNDER THE HOOD CUT-OFF SWITCH/2.5" SS lift/1"M.O.R.E BL/33" BFG KM2 ON STOCK 17"/RIVER RAIDER ROCKER GUARDS-SLIDERS/OFF ROAD HEROS FASTBACK SOFT TOP/GIBSON DUEL EXHAUST/CUSTOM MADE TRUNK/HELLA FF300/HELLA500 W-WINDSHIELD MOUNTS/DELTA SKYBAR/CARBON FIBER DASH KIT/DUEL AND SINGLE GUAGE PODS WITH VOLT-OIL PRESSURE-OIL TEMP GUAGES/COBRA 75 CB/AND A LOT OF RECOVERY GEAR
JMP8562 is offline
post #92 of 117 Old 04-14-2013, 08:34 AM
DirtyTires
2011 WK
I saw on another thread somewhere that someone mounted a different winch, but it didn't exactly fit and they had to do a bunch of adjustments to get it in there properly. I'm still waiting on mine to get shipped!
2011 Laredo X 4x4, ORA 1, Quad Trac II 4WD, Wild Country XTX Sport 265/70/17, American Racing ATX series AX188 Ledge, RRO 2.5 lift, PIAA 510 & 520 ATP Aux lights, Yakima roof rack, Mopar rock rails, dealer OEM hitch, RR winch mount and brush bar, Smitty 10K winch, RR pre-runner skid plate, slightly de-chromed.
DirtyTires is offline
post #93 of 117 Old 04-14-2013, 05:15 PM
JMP8562
OK, thanks for the reply and i did see that the following dose fit got this from another forum
Measurements are L x D x H
Smittybilt XRC10000 - 21.15" x 6.3" x 8.6"
Smittybilt XRC10000Comp - 21.15" x 6.3" x 8.6"
Warn M8000 - 21.04" x 6.3" x 7.6"
Warn VR10000 - 20.8" x 6.3" x 6.97"
JMP8562 is offline
post #94 of 117 Old 05-04-2013, 01:08 PM
txwest
2012 WK
Winch Install Help
Originally Posted by rpoverland View Post
Here are some pictures of my winch before we put the bumper back.
We have to cut some holes in the mesh grill in order to access the winch cable release and another one I connect the cable that controls the winch.
I would send a PM but your inbox is full........
Well,
After Jackal01 and I have salivated for so long seeing your Jeep with a winch I have decided to get one for my '12. I was wondering if there is anything additional that would make life easier for the install. Additional body panel rivets/fasteners, etc etc. Anything that you discovered you needed, once you were already in the middle of the install.
Also, I was wondering if you looked into alternative locations for the control box? I am not that excited about having it smack dab in the middle of my grill. I am looking at placing it somewhere else if possible. Somewhere up and out of the weather and road grime. I live in South Texas and try to keep the radiator as free as possible for air flow on those 110+ deg days. Jacakl01 and I appreciate any insights you can provide us. We plan on fully documenting the install so he can do it to his Jeep, and we can post a full install thread here on the forum.
Thank you for any information you can give us!
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline
post #95 of 117 Old 05-04-2013, 02:07 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Yea...what he said! Lol
Sent from my underground lair.
2011 Billet JKUS
Jackal01 is offline
post #96 of 117 Old 05-17-2013, 04:00 PM
txwest
2012 WK
OK........
Purchased the Winch Kit from RRO and an 8k synthetic winch from Smitty.
All things considered, I might get it in there before 4th of July. Work is a little crazy and I have to work a bunch of weekends.
Will post everything to a full write-up thread once it is complete.
Wish me luck!
Current:
Past Jeeps:
'80 CJ-7 I6 4x4 Std
txwest is offline
post #97 of 117 Old 05-17-2013, 06:43 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Originally Posted by txwest View Post
OK........
Wish me luck!
Im excited to help!! Cannot wait. Lol
2011 Billet JKUS
Jackal01 is offline
post #98 of 117 Old 05-19-2013, 03:38 PM
volvite
Waiting for pictures.
His 99 WJ Limited 4.7
Hers 15 Overland EcoDiesel, ORAII
volvite is offline
post #99 of 117 Old 05-19-2013, 04:54 PM
DirtyTires
2011 WK
I got mine in this weekend! I am posting up on it in my Jeep's thread, page 3:
http://www.jeepforum.com/forum/f309/...l#post15446858
post #100 of 117 Old 05-25-2013, 04:51 PM
jch3CJ7
2012 WK
OK........
Wish me luck!
That's exactly what I'm planning on doing. Can't wait to see yours
jch3CJ7 is offline
post #101 of 117 Old 05-26-2013, 06:51 AM
txwest
2012 WK
Looks like the install should happen next weekend. I picked up a smaller hawse and measured the front license plate holder. Looks like it will be within millimeters of fitting behind it. I will have to cut most of the back plastic out, but it will still mount up. I took the solenoid and plug box apart and have found a nifty hiding place for it under the hood. All that is left is to find a good spot to extend the plug-in to for easy-to-use access without opening the hood. Stay tuned!
Sent from my S-III using JeepForum
Current:
Past Jeeps:
'80 CJ-7 I6 4x4 Std
txwest is offline
post #102 of 117 Old 05-26-2013, 07:46 PM
JMP8562
I got Mine Installed (by the dealer ) But my Warn 9.5 Did Not fit Looks like i will have to save a few more $$$$
JMP8562 is offline
post #103 of 117 Old 05-26-2013, 09:06 PM
txwest
2012 WK
Only $449 for an 8k synthetic line.
Current:
Past Jeeps:
'80 CJ-7 I6 4x4 Std
txwest is offline
post #104 of 117 Old 05-27-2013, 07:45 AM
JMP8562
Thanks BUT the WARN 9.5 is right at the Low end for the weight of the WK2s. The rule is Double the weight of the vehicle
I am looking at the WARN VR10000 that should get it out of Just about anything
JMP8562 is offline
post #105 of 117 Old 05-27-2013, 07:52 AM
txwest
2012 WK
Snatch block and a recovery strap, doubles the line pull. Good enough for me.
Current:
Past Jeeps:
'80 CJ-7 I6 4x4 Std
txwest is offline
Custom winch bumper for GC MAXGroup WK2 Grand Cherokee Forum 2 03-15-2012 03:30 PM
Pic of WK2 with front bumper off? Rckstar113 WK2 Grand Cherokee Forum 4 03-05-2012 11:08 PM
WK2 Winch Options??? Lakeboy106 WK2 Grand Cherokee Forum 7 03-01-2012 06:35 AM
Front winch bumper design JMP8562 WK2 Grand Cherokee Forum 6 02-28-2012 07:40 PM
Viper Max Winch Giveaway Ends Tomorrow - ENTER NOW! JF_Admin WK2 Grand Cherokee Forum 0 10-19-2010 09:39 AM
