rotational clicking from rear? park brakes? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > rotational clicking from rear? park brakes?
Clayton Off Road JK Short Arm Suspension Kits~Artec JK 1 TON SWAP~Engo winches available at www.rockridge4wd.com! Free shipp
Unread 09-14-2014, 01:03 PM   #1
Angela11
2011 WK
Hi,
I have a 2011 overland that is making a rotational clicking ticking noise while driving (hear it best when passing close to buildings or in parking garage). Faster than the tire rotation but speeds up and down according to vehicle speed. Dealer change both left axles Friday, but noise is still there. Sounds a bit metallic in nature. Could the parking brake pads have let go and rattling around? Any thoughts? They say everything underneath is solid.
Angela11 is offline   Reply With Quote
Unread 09-14-2014, 01:13 PM   #2
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Could be a wheel bearing, but you would think they would have heard the tick while turning the wheels on the lift for the axle replace.
Parking brake pads letting go usually means you stop and can't move. Could be some debris in them, or a loose suspension component.
Perhaps the new axle has a defect.... just guessing... The lug nuts are tight?
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now   Reply With Quote
Unread 09-14-2014, 01:20 PM   #3
Angela11
2011 WK
It went in for the noise and they replaced axles but left the noise....
They said they checked the wheel bearing and all was good. Back in tomorrow.
Unread 09-15-2014, 04:58 PM   #4
Angela11
2011 WK
So we are now annoying noise-free...if you can believe it, it was...a part sticker hanging down and ticking on the drive shaft!
