Rhino-Rack crossbars on my new WK2 - JeepForum.com
post #1 of 58 Old 02-01-2015, 09:54 AM Thread Starter
jmc777
2015 WK
Just installed the Rhino-Rack crossbars (RSP27) on my new WK2. Installation is easy, just make sure you have a T-30 torx handy to remove the factory bolts. I'm really happy with them - well designed and very sturdy. Might even risk the car wash without removal, although the manual says to take them off. Here are a couple of pictures...
jmc777 is offline
post #2 of 58 Old 02-02-2015, 01:28 PM
2kg4u
2014 WK
Why do you have to remove factory bolts? Which ones? What did this cost you?
I like the look.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline
post #3 of 58 Old 02-03-2015, 10:39 AM Thread Starter
jmc777
2015 WK
The crossbars sit on four baseplates that mount inside the roof tracks. New bolts are supplied (replacing the t-30 factory bolts which you can see if you look down into the tracks) to secure the baseplates. A total of 6 bolts (2 front 1 rear on each side) are replaced. The new bolts require a special tool so the benefit is that it would be harder to steal the rack. Once fully installed you can remove the crossbars easily (4 bolts) but the baseplates stay in place. Amazon has it for $270.
jmc777 is offline
post #4 of 58 Old 02-04-2015, 01:23 PM
2kg4u
2014 WK
So, if you are securing the baseplates to the roof tracks, does that mean they can't be adjusted fore/aft?
Roy
2kg4u is offline
post #5 of 58 Old 02-04-2015, 05:26 PM Thread Starter
jmc777
2015 WK
Correct.
jmc777 is offline
post #6 of 58 Old 02-04-2015, 09:18 PM
pentastarguy
2015 JK Wrangler
very nice. any increased wind noise?
pentastarguy is offline
post #7 of 58 Old 02-05-2015, 09:46 AM Thread Starter
jmc777
2015 WK
I haven't noticed any increased wind noise at all.
jmc777 is offline
post #8 of 58 Old 02-05-2015, 09:11 PM
perpster
2015 WK
Nice. Odd that the OEM baseplates (fore-aft on L and R) are 100% flush with roof -- no place to slip a rope or bungee through.
perpster is offline
post #9 of 58 Old 02-05-2015, 10:02 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Style won out over function.... although the ends of the OEM bars stick out beyond the baseplates and provide an opportunity for tied downs.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #10 of 58 Old 02-06-2015, 12:43 AM
perpster
2015 WK
Thanks for pointing that out ColdCase!
perpster is offline
post #11 of 58 Old 03-06-2015, 02:27 PM
pinaplebob
2011 WK
JMC... Can you post a pick of your jeep from the front with the roof rack. Just curious how high they are above the roof. Out of everything out there right now, these are the bars i'm leaning towards right now.
pinaplebob is offline
post #12 of 58 Old 03-07-2015, 07:31 AM Thread Starter
jmc777
2015 WK
Here you go. BTW I've been through the car wash several times with these attached without a problem.
jmc777 is offline
post #13 of 58 Old 03-07-2015, 11:11 AM
pinaplebob
2011 WK
Thank you very much. They look a lot shorter then the MOPAR bars to me at least and look more factory. Thank you for taking the time to post. You have made up my mind.
post #14 of 58 Old 03-11-2015, 04:00 PM
migganimon
Thinking of picking these up myself. Any noticeable impact on MPG?
migganimon is offline
post #15 of 58 Old 03-13-2015, 05:35 AM Thread Starter
jmc777
2015 WK
I don't know. I haven't been paying attention to mpg since the vehicle is new and has spent so much time warming up in morning.
jmc777 is offline
