Remove your grill WITHOUT removing the bumper cover - JeepForum.com
 2Likes
  • 2 Post By slayer6x6
post #1 of 9 Old 07-04-2014, 11:27 AM Thread Starter
slayer6x6
It seems that after searching, most instructions have you remove the bumper cover if you'd like to swap or paint your grill. This seems like a lot of work for a very simple job. I'm not the first one to figure this out, but some of the other instructions are a bit difficult to find, so hopefully this thread will pop up for new members that are searching. Props to Nubby105 for digging up the original instructions. I'd figure I would post this while I'm waiting for my plasti dip to dry.
Before you start, having a set of these inexpensive plastic panel tools will make your job a bit easier.
You want to start by pulling up gently on this plastic trim piece to release the metal panel clips underneath.
Once you have released all of those clips, you'll be able to pull that piece forward to expose the clips that actually hole the grill on, pictured here.
Once you can see those retaining clips, you can grab you plastic wedges and gently spread apart the black plastic clips while pulling gently on the grill to free the chrome part of the grill. I recommend you start with the outer most clip and work your way across, they tend to get easier as you move along.
Once the entire top row of clips is released, you can pull gently across the bottom part of the grill to release the lower clips. Those come off a lot easier than the top ones.
And its as easy as that, hopefully this saves somebody from pulling the entire bumper cover, just like I was about to do. Good luck.
BolderGuy and KornFed like this.
slayer6x6 is offline
post #2 of 9 Old 07-04-2014, 12:09 PM
nubby105
2011 WK
Nice post.
nubby105 is offline
post #3 of 9 Old 07-04-2014, 12:26 PM
petetherocker
2012 WK
I'm not sure what year yours is, but mine is a 2012, and there are 2 lower fasteners (bolts) # 3 in image below that secure the grill assembly to the vehicle, and they CANNOT be accessed without removing the fascia. I know because I've done it.
2001 XJ Limited 4.0 Litre
2005 WK Limited 5.7 Litre
2012 WK2 Overland (current)
petetherocker is offline
post #4 of 9 Old 07-04-2014, 12:45 PM Thread Starter
slayer6x6
Thats odd, mines a 2011. I couldn't imagine they changed from year to year, but I guess anythings possible.
post #5 of 9 Old 07-04-2014, 01:31 PM
97HMCS
2012 WK
I think slayer6x6 is just pulling the outer shell.
In either case, it's not terribly difficult to simply remove the bumper cover.
97HMCS is offline
post #6 of 9 Old 07-07-2014, 07:03 AM
nubby105
2011 WK
Chrome Only Removal
The Chrome Only piece can be removed without the bumper being removed.
nubby105 is offline
post #7 of 9 Old 11-18-2014, 02:14 PM
Dirtymark
2012 WK
Originally Posted by slayer6x6
It seems that after searching, most instructions have you remove the bumper cover if you'd like to swap or paint your grill. This seems like a lot of work for a very simple job. I'm not the first one to figure this out, but some of the other instructions are a bit difficult to find, so hopefully this thread will pop up for new members that are searching. Props to Nubby105 for digging up the original instructions. I'd figure I would post this while I'm waiting for my plasti dip to dry. Before you start, having a set of these inexpensive plastic panel tools will make your job a bit easier. You want to start by pulling up gently on this plastic trim piece to release the metal panel clips underneath. Once you have released all of those clips, you'll be able to pull that piece forward to expose the clips that actually hole the grill on, pictured here. Once you can see those retaining clips, you can grab you plastic wedges and gently spread apart the black plastic clips while pulling gently on the grill to free the chrome part of the grill. I recommend you start with the outer most clip and work your way across, they tend to get easier as you move along. Once the entire top row of clips is released, you can pull gently across the bottom part of the grill to release the lower clips. Those come off a lot easier than the top ones. And its as easy as that, hopefully this saves somebody from pulling the entire bumper cover, just like I was about to do. Good luck.
Just came across your post. How hard was it to put the grill back on and secure it to the clips? Did you just reverse the steps and good to go?
Dirtymark is offline
post #8 of 9 Old 11-18-2014, 05:31 PM
kryogen
2011 WK
you know what, I would just remove the bumper and grille, probably easier and faster,
2011 Grand Cherokee Overland V8, QD, QL
Nokian Hakkapelita 8 SUV Studded winter tires
kryogen is offline
post #9 of 9 Old 02-24-2017, 05:27 PM
kyoboof
Thanks for the write-up. I plan on Vinyl wrapping mine soon. Very useful info.
kyoboof is offline
