Remote start abort due to hood open? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Remote start abort due to hood open?
Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **dea
Unread 02-09-2016, 11:12 AM   #1
dtrkyman
2013 WK
Have this warning on mine at the moment, vehicle was actually sitting for about 10 days and worked fine prior, tried opening and closing hood and wiggled the sensor around a bit. Are there any aftermarket parts if i need a new one?
dtrkyman is offline   Reply With Quote Quick reply to this message
Unread 02-09-2016, 12:03 PM   #2
MyWay1
I have the same issue, but have been too lazy to take it in just for this, I plan on dealing with it my next oil change.
MyWay1 is offline   Reply With Quote Quick reply to this message
Unread 02-09-2016, 12:15 PM   #3
dtrkyman
2013 WK
Still too cold here, I need to fix!
Unread 02-09-2016, 12:30 PM   #4
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
My understanding is the switch is built into the hood latch and you need to replace the latch. $40 at moparonlineparts.com, $57 or less at dealers. Part number 04589687AA, I think, for 2013. Its used in a wide variety of Chrysler vehicles.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 02-09-2016, 12:46 PM   #5
dtrkyman
2013 WK
Thanks, is it pretty straight forward to remove? I see the connection next to the latch. I am going to try and unplug it and see how it comes apart, but damn its like 15 degrees here!
Unread 02-09-2016, 02:21 PM   #6
ColdCase
ColdCase's Avatar
2011 WK
There are two domestic versions of the latch, one with remote start (has the switch) another version for vehicles without remote start (no switch).
Unread 02-09-2016, 08:35 PM   #7
dtrkyman
2013 WK
so you have to buy the whole assembly not just the switch?
Unread 02-09-2016, 08:50 PM   #8
ColdCase
ColdCase's Avatar
2011 WK
Dunno but the parts book says the 04589687AA switch is only available as part of the $50 hood latch assembly. The FSM says "An installed hood ajar switch cannot be readjusted or repaired. If the switch is damaged, ineffective, or requires readjustment, it must be replaced with a new unit."
The switch is a normally closed, single pole, spring-loaded plunger actuated switch. If you want to compromise the safety device, you could try to disconnect the wires and see if remote start works, if not then short the contacts and see what happens. Add some duct tape for effect.
Unread 02-10-2016, 03:56 PM   #9
2kg4u
2014 WK
^^^ This. Pull the electrical connector and short the contacts.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline   Reply With Quote Quick reply to this message
