Recall issued today for G.C. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Recall issued today for G.C.
Want to be able to SEE? DOT Approved Headlights for under Coil Spring Options from Ruffstuff!Flush Mount LED Bumper Lights, CREE
Unread 10-29-2014, 08:25 PM   #1
blackfoot
Recalled issued today for Ram trucks and G.C.Go to goggle and put in Jeep recalls to get the info.
blackfoot is offline   Reply With Quote Quick reply to this message
Unread 10-29-2014, 08:30 PM   #2
airgas1998
2014 WK
were on a roll...thank god I don't own an April built gc....
14' JGC Limited 4x4
airgas1998 is offline   Reply With Quote Quick reply to this message
Unread 10-29-2014, 09:25 PM   #3
14summithemi
2014 WK
? They give build dates for this one?
14summithemi is online now   Reply With Quote Quick reply to this message
Unread 10-30-2014, 10:46 AM   #4
Bullheadbud
2014 WK
Link?
Bullheadbud is offline   Reply With Quote Quick reply to this message
Unread 10-30-2014, 11:41 AM   #5
mx71
2013 WK
http://money.cnn.com/2014/10/29/auto...all/index.html
mx71 is offline   Reply With Quote Quick reply to this message
Unread 11-02-2014, 12:57 PM   #6
14summithemi
2014 WK
Here's the official FCA press release....
http://media.chrysler.com/newsreleas...=16153&mid=431
Unread 11-08-2014, 11:15 PM   #7
14summithemi
2014 WK
P64 Recall
Is this P64 the same recall? The Gov't letter link is below and it gives a date range of "certain" vehicles manufactured October 3, 2013, to April 11, 2014.
This one is also for ESC but a pure software deal vs the OP's posted one of ESC disabled from cover that causes blah blah and the fix is part/all physical.
http://www-odi.nhtsa.dot.gov/acms/cs...4V636-7256.pdf
UPDATE:
Looks like the usual press release confusion just before the recall is finalized. Many media reports, the US DOT letter and the FCA press release use the same 132,223 pool size when discussing both ESC "recalls", debris cover version and no debris cover/software update only version. Since I am in the date range we shall see soon enough if I am one of the "certain" vehicles. It's an easy one, no biggie.
UPDATE #2:
And this doc clearly shows they are the same "recalls"....
"Description of the Cause : • The root cause was determined to be noise on a PCB communication line, between
the main and the sub-microprocessor, resulting in an over-run condition during an
18-msec window at vehicle start-up.
• On October 3, 2013, a plastic shield was added to the SCCM to protect the Printed
Circuit Board (PCB) from metallic debris.
• The noise is the result of the debris cover coming into contact with the PCB
communication lines, while the micro pins are being configured and during a period
of higher humidity, causing a short (noise).
• This noise, which may be treated as data during the 18-msec window, results in an
over-run condition which freezes communication between the two micros."
http://www-odi.nhtsa.dot.gov/acms/cs...4V636-6439.pdf
Unread 11-29-2014, 09:37 PM   #8
Kablemodem
2014 WK
I received the notice today. 14 Overland V6 MDH 022820
Kablemodem is offline   Reply With Quote Quick reply to this message
Unread 11-29-2014, 09:42 PM   #9
14summithemi
2014 WK
Me too but I already had this P64 recall (link below) done during visit last week. Its just a reflash.
http://www.wk2jeeps.com/tsb/rc_P6414.pdf
I am still waiting on the P67 recall for the ORC module replacement. That should be a joy with what has got to turn into a crazy parts backorder scenario. It says 126,772 rigs are affected and they made approx 193,290 (just assumed '13 sales='14 sales for lack of data) during the date range which is about 65.6% of production so we shall see if I win the lottery. Good news is it says only 5% of the lottery "winners" truly win
http://www-odi.nhtsa.dot.gov/acms/cs...4V643-9760.pdf
Unread 11-30-2014, 09:38 AM   #10
goin2drt
2013 WK
I have a feeling it is only going to get worse before it gets better. Every company is going way over to error on the side of being safe with all these huge lawsuits. Anything and everything is getting recalled where as I bet before many were so minor that they would have just fixed the few rather than recall them all.
2013 GC Trail hawk. Fully loaded in black.
goin2drt is offline   Reply With Quote Quick reply to this message
Unread 12-07-2014, 12:57 PM   #11
14summithemi
2014 WK
YEAH! Just confirmed my rig is in the 34.4% (my calculated guess) of production not affected. Whew, I suspect it will be afun backordered part type recall given it's the ORC module. May you all be in the same unaffected population! They said letters are in the mail now.
