Rear view mirror operation? - JeepForum.com
post #1 of 18 Old 11-03-2010, 02:23 PM Thread Starter
diegom6
Gave a quick look at the rear mirror and noticed it has a little buttom to power the automatic darkness when the headlight of a car behind hit it. Does it have a led or soemthign that let you know when is on or off? Couldn't find it, nor couldn't know if it was ON or OFF actually.
Thanks
XJ: 4.6L High Output Stroker Forged Bottom
- Powerdyne Supercharger
- WJ Twin Caliper/Big Rotor Custom Kit
- ARB Lockers
-Dana30 -Dana44 Rear
- AX15
diegom6 is offline
post #2 of 18 Old 11-03-2010, 05:42 PM
darkrt
2014 WK
It has a green led that shows on the button when its on. It only shows when the ignition is on.
darkrt is offline
post #3 of 18 Old 11-04-2010, 07:41 AM Thread Starter
diegom6
and you can see it better (obviously) in nights. Just checked it, thanks.
- ARB Lockers
- AX15
diegom6 is offline
post #4 of 18 Old 12-11-2010, 06:12 PM
jeepsterguy
2011 WK
I have the same mirror, its supposed to change when there is a car behind me, right?
I switched it off and on and I see no difference. Am I missing something?
jeepsterguy is offline
post #5 of 18 Old 12-11-2010, 07:19 PM
mjw930
It's only active when is senses the headlights from behind. Typically, unless the car is within 10 car lengths behind you it's not bright enough to trigger the sensor and darken the mirrors.
mjw930 is offline
post #6 of 18 Old 12-11-2010, 07:41 PM
jeepsterguy
2011 WK
10-0 car lengths, I see no difference on or off. The rear window is tinted and it cuts some of the light off, other than that, I can't tell.
post #7 of 18 Old 12-11-2010, 07:44 PM
mjw930
Then you don't have it switched on or it's not working.
mjw930 is offline
post #8 of 18 Old 12-11-2010, 07:47 PM
jeepsterguy
2011 WK
The green light goes on and off when I cycle the switch but nothing happens.
post #9 of 18 Old 12-11-2010, 07:53 PM
2011Hemi
2011 WK
In addition to the above, it only functions when YOUR headlights are on.
2011Hemi is offline
post #10 of 18 Old 12-11-2010, 07:56 PM
jeepsterguy
2011 WK
Headlights are on.
post #11 of 18 Old 12-11-2010, 08:03 PM
2011Hemi
2011 WK
I would say yours has a malfunction in it somewhere. I know mine gets very dark pretty quick when someone in behind me. It seems to take longer to go back to normal (clear) mode than it does to darken.
Try using a flashlight and point it at the sensor on the inside mirror.
2011Hemi is offline
post #12 of 18 Old 12-11-2010, 08:15 PM
jeepsterguy
2011 WK
If it takes longer to go back to normal, turning the switch on and off is not the way to test it.
I will try the flashlight and also start with the switch off and when I see a car behind me, I'll turn it on again.
Thanks.
One thing I noticed is that both the rear and side mirrors don't produce a lot of reflection even when the car behind me has the high beams on.
post #13 of 18 Old 12-13-2010, 06:43 PM
jeepsterguy
2011 WK
I used the flashlight, it does darken, not as much as I expected. Thanks now I know that it works.
post #14 of 18 Old 12-14-2010, 07:43 AM
JTS97Z28
The jeep has auto dimming side mirrors as well I would assume correct? Atleast most other cars that have an auto dimming inside mirror that same switch also controls the outside auto dimming function as well. Just wanted to double check that those dim as well as I'm pretty sure I remember my 05 limited and 08 SRT8 had power, heated, dimming outside mirrors.
James
JTS97Z28 is offline
post #15 of 18 Old 12-14-2010, 08:14 AM
zman
I don't believe the side mirrors are auto dimming. I have this same mirror on my 2003 Rubicon. As far as not working, if your rear window is limo tint I could see why the auto dimming feature does not work. Also I have been told (never did confirm) it senses daylight/night and not controlled by the headlight switch. When dark outside it will dim when it senses headlights from behind.
1995 YJ on 40's * 2002 TJ on 37's * 2003 TJ on 33's * 2011 WK Larado X w Hemi
zman is offline
I Bought the Chrome Mirror Covers but... :-( Dabitz WK2 Grand Cherokee Forum 37 02-15-2016 10:53 AM
Button on rearview mirror RRER WK2 Grand Cherokee Forum 4 10-06-2010 01:10 PM
2011 Limited width/mirror question (+ genuine amazement!) stumil WK2 Grand Cherokee Forum 8 08-16-2010 02:36 PM
