Rear tow hook wk2 grand cherokee??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Rear tow hook wk2 grand cherokee???
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 02-10-2016, 06:00 PM   #1
Limited9627
2014 WK
I know the front tow hooks are pretty easy to find and on ebay for about $180 but while looking on moparpartsdepot.com on the diagram of the rear number and tow hitch, I noticed there was a rear to hook separate from the tow hitch. Can this rear tow hook be installed on any of the WK2 without the tow hitch? Has anyone installed a rear tow hook on a WK2?
Limited9627 is offline   Reply With Quote Quick reply to this message
Unread 02-10-2016, 07:39 PM   #2
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The hook is suppose to be there OEM unless replaced by a tow hitch.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 02-10-2016, 08:44 PM   #3
Limited9627
2014 WK
Are you telling me I should have a tow hook!? I looked and didn't see one. You probably have one because you have an overland and you should have front tow hooks as well. I have a Limited.
Unread 02-10-2016, 08:55 PM   #4
ColdCase
ColdCase's Avatar
2011 WK
I had forgotten that rear tow hooks were dropped from standard equipment in 2014. See this thread for info:
http://www.jeepforum.com/forum/f309/.../#post31952538
Unread 02-10-2016, 10:02 PM   #5
Limited9627
2014 WK
Okay but they should fit on my vehicle? I could actually buy an aftermarket tow hitch for cheaper than the mopar tow hook. I've seen aftermarket tow hitch that goes under the rear bumper for about $120 with free shipping but I would loose departure angle. Or I could get either an OEM tow hitch or aftermarket one that goes behind the bumper but I would imagine I would have to replace the lower part of the bumper with one that have a removable panel which hides the receiver and plug? It sounds like a straight forward question but when I called the Bayside jeep dealer from MoparPartsDepot.com the guy in the parts department couldn't give me an answer. and he said when he punched in my Vin the tow hook wasn't available for my vehicle. I don't know if that's because it didn't come with one or because it won't fit. He couldn't tell me.
Unread 02-10-2016, 11:22 PM   #6
ColdCase
ColdCase's Avatar
2011 WK
There are a few hitch install threads in the forum as well as some good advice. Do you have a Summit or SRT or high Altitude? If not the OEM hitch just requires a hole to be cut in the bumper cover and trim piece installed. Check the install instructions at forum sponsor moparonlineparts.com accessory catalog. If you want trailer lights, the TIPM would need to be flashed by a dealer.
Dealers typically will not guaranty a part will fit if it doesn't show up as applicable to the VIN. Since your VIN did not have a rear tow hook, it would not show up. If you purchased the hook anyway, its yours.... no returns typically.
Unread Yesterday, 04:06 AM   #7
Limited9627
2014 WK
I have a Limited. Since I found a tow hitch on Amazon for $86 that goes under the rear bumper, I think I'll be getting that instead of a tow hook. Not only is the OEM hitch more expensive but I'd rather not have to do any cutting. I expect I will loose some departure angle with an under the bumper style hitch but hopefully not much.
I don't expect to I'll need to tow a trailer any time soon but if I do I'll just have to get the wiring and just have the computer flashed. I do need a hitch as a recovery point and I will also be able to use it to mount a flag if I visit an off-road park.
Unread Yesterday, 02:45 PM   #8
NDSU_Bison
2014 WK
I don't think a rear tow hook has ever been standard. Even with my 1998 Cherokee, the optional tow hooks included one rear hook which was deleted if you have the hitch receiver.
NDSU_Bison is offline   Reply With Quote Quick reply to this message
