Rear brakes wearing out faster than front - JeepForum.com
post #1 of 36 Old 08-16-2013, 12:12 PM Thread Starter
rmac427
Just took my 2012 Grand Cherokee V6 4x4 in for an oil change, and was told that my rear brakes are almost worn out, but my fronts still have plenty of life left on them.
The Jeep only has 16,000 mi. on it and the rear brake pads only have 3mm left while the front pads have 7mm per the technician.
There were no signs of the calipers sticking or getting hung up.
Shouldn't the front and rear brakes wear evenly, or at least the fronts should wear out faster than the rears because they do most of the braking?
Is there a proportioning valve on this system that maybe isn't set properly?
Any ideas what might be causing this?
rmac427 is offline
post #2 of 36 Old 08-16-2013, 07:40 PM
tjkj2002
2002 KJ Liberty
Your Jeep in normally in RWD and with ESP and traction control the rear brakes will wearout faster then the fronts with those driving aids.Even if you don't know it or feel it those rear brakes are engaging more often then you think.
tjkj2002 is offline
post #3 of 36 Old 08-16-2013, 09:00 PM
loveracing1988
No matter what though, unless you are constantly spinning the tires brake pads should not wear out in 16,000 miles.
loveracing1988 is offline
post #4 of 36 Old 08-16-2013, 09:27 PM
tjkj2002
2002 KJ Liberty
Tell that to Chrysler minivan owners,lucky to get 20k out of the front brakes before there metal to metal.Same problem from '96-'13 models.
tjkj2002 is offline
post #5 of 36 Old 08-16-2013, 10:10 PM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
I checked mine earlier today and mine are still about half way through the original pads. Fronts are worn less than rears; normal.
2011 Billet JKUS
Jackal01 is offline
post #6 of 36 Old 08-17-2013, 11:17 PM
NDSU_Bison
2014 WK
My 2008 WK does the same thing. I do a lot of highway driving and had the rear pads replaced at about 110,000 miles. The fronts are still OK at 128,000 miles.
NDSU_Bison is offline
post #7 of 36 Old 08-17-2013, 11:26 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
We always got 80,000 + miles on the three minivans we had during that period....
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #8 of 36 Old 08-17-2013, 11:51 PM
ColdCase
ColdCase's Avatar
2011 WK
Well the parking brake uses the drum, not the pads... so someone hasn't been driving with the parking brake on.
The service manual says they use a Electronic Variable Brake Proportioning designed into the combined hydraulic control unit and ABS module which eliminates the typical combination/proportioning valve. Its a four channels sytem with each caliper directly connected to the HCU. As far as I can tell there are no manual adjustments, although the dealer's scanner may have some kind of capability.
I would suspect something amiss in the HCU/ABS module or perhaps sensors. Perhaps the control system thinks the rear tires are spinning faster than the fronts, and are routinely applying the rear brakes.
Unless you have someone riding the brakes, 16,000 miles is a bit short.
Rears brakes use smaller pads and are lighter duty than the fronts, so they could wear faster than the fronts. Our WJs alway wore fronts twice as fast as the rears, however.
There are a number of things that will cause brakes to be applied automatically, yaw, stability, wipers, along with traction.
ColdCase is offline
post #9 of 36 Old 08-21-2013, 11:37 AM
ColdCase
ColdCase's Avatar
2011 WK
Did you get this sorted out?
While perusing for another issue I ran across the reminder that the master cylinder has two pistons, one for fronts, one for rears and this proportioning description. Both my front and rear pads have plenty left after 36,000 miles mostly highway. Hard to tell if one set is wearing faster than the other.
ColdCase is offline
post #10 of 36 Old 08-21-2013, 04:19 PM
Dave2002ti
2012 WK
My 2012 Grand Cherokee Laredo X AWD with the ORAI package is in RWD normally??? Really? And you are a mechanic.
If OP's rear brakes are wearing out there is a problem. Either with driving style or more likely a failure of some component.
The front brakes of most vehicles do approx 70% of the braking. You do not want the rear brakes doing much more than 30% because then you run into all kinds of balance and handling issues. Race cars have an adjustable proportioning valve you use this compensate for wear, weather, and track conditions.
Dave2002ti is offline
post #11 of 36 Old 08-21-2013, 06:51 PM
Jpiwonski
2011 WK
Was it the outside or inside pad or both that was down that far?
Jpiwonski is offline
post #12 of 36 Old 08-21-2013, 07:13 PM
ColdCase
ColdCase's Avatar
2011 WK
True, but many manufactures now skimp on rear shoe material (a lot smaller pad), so they can wear out faster than the front even at 30% load.
In any case, worn pads at 16K miles is not right regardless.
ColdCase is offline
post #13 of 36 Old 08-22-2013, 05:21 AM
Dave2002ti
2012 WK
Back in 1970
Porsche 1970 911S had a smaller rear pad for the rear disc brakes. I cant remember if it was thinner. 1974 Lotus Europa was similar. My 87 GTI 16v with read discs the rear pads were smaller and thinner. Same with 90 325i.
A M3 from the same year also had smaller rear pads and the pad was thinner.
post #14 of 36 Old 08-22-2013, 08:10 AM
ColdCase
ColdCase's Avatar
2011 WK
Yes, as do all my cars as you don't need as much pad material and don't want extra unsprung weight by design. I'm just saying that it seems like, for some models, a bean counter saw extra rear pad material for the a car's design life and found way to save a few $$ per car by skimping. So the rears wear out before or near the same time as the fronts.
ColdCase is offline
post #15 of 36 Old 08-22-2013, 08:50 AM
tjkj2002
2002 KJ Liberty
With a selectable 4wd system it is moron,even AWD's are not always AWD(50/50 split).In your case it's more power to the rear then front.With more power going to the rear with a front engine design your going to to have more slippage.
tjkj2002 is offline
