Question about TSB 21-007-13 REV. B - JeepForum.com
post #1 of 9 Old 11-18-2013, 12:22 AM Thread Starter
pt2005
2014 WK
Hi all,
I learned from this forum about this TSB and I have a few questions. Sorry if I ask obvious questions but I'm not a Jeep guy...yet
1) TSB says "applies to vehicles built on or before August 12, 2013" but the reading on my driver door says "MFR 8-13". Looks like it only shows the month of Aug but not the date. Safe to proceed anyway?
2) My versions on the UConnect says the Software Version 13.26.0, and HMI Version 13.26.01? Are these UConnect version or something else?
3) Is this TSB "do it yourself" or I have to bring it to the dealer? Approximate time needed?
4) Those who have done this flash: do you see significant improvement transmission-wise and performance-wise? (i understand if mpg is compromised)
Your response is very much appreciated.
Thanks
2014 Grand Cherokee 3.6 Laredo 4x2
pt2005 is offline
post #2 of 9 Old 11-18-2013, 10:22 AM
jacko15
2014 WK
This flash is a dealer only. To find out if you need it, your dealer should be able to tell by your vin. If you take your Jeep in for service of any kind it should be applied. I haven't had it done yet, but will when I go in for an oil change, along with several other flashes my Jeep needs. Anecdotal evidence is that getting the flash will improve transmission responsiveness.
Hers: 2008 Jeep Compass Sport
Mine: 2014 Jeep Grand Cherokee Overland V/6 ORA II
Michelin LTX M/S 2's
jacko15 is offline
post #3 of 9 Old 11-18-2013, 05:49 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
It does show the date elsewhere on the sticker, don't recall off hand, but someone here discussed it a month or so ago. Sorry not much help.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 9 Old 11-18-2013, 06:37 PM
WK2FAN
2012 WK
On the bottom right side of the sticker is an entry labeled MDH for month/day/hour
WK2FAN is offline
post #5 of 9 Old 11-18-2013, 10:54 PM Thread Starter
pt2005
2014 WK
I checked the windows sticker, and it says "0810" at the right of the VIN. Looks like it was built 08/10/2013 which is 2 days of the cutoff day spelled out on this TSB. I'll bring it in to the dealer and will update the forum about the performance after the fix.
Thank you all.
pt2005 is offline
post #6 of 9 Old 12-11-2013, 10:45 PM Thread Starter
pt2005
2014 WK
Update:
I'm the OP and I just have the dealer update the flash to TSB 21-007-13 REV. B, which supposed to enhance upshift/downshift issues but I've NOT seen any difference/improvement after the fix. However, I do notice a drop in mpg. Any body experience the same behavior after flashing?
P.S. It's been 16 miles of driving since the flash update (the vehicle has been restarted about 5 times)
Thanks
pt2005 is offline
post #7 of 9 Old 12-12-2013, 01:16 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
The dealer did the Service Bulletin even though it did not apply to your Jeep? Did you have any of the symptoms/conditions?
NUMBER: 21-007-13 REV. B
GROUP: Transmission and Transfer Case
DATE: October 12, 2013
SUBJECT: Flash: Transmission and Transfer Case Shift Enhancements
OVERVIEW:
**This bulletin involves verifying whether or not the Transmission Control Module (TCM)
software is at the latest level and if not, flash reprogramming the Transmission Control
Module (TCM) with new software. In addition, flash reprogramming the Transfer Case
Drive Train Control Module (DTCM) on 4X4 vehicles.
NOTE: All Wheel Drive (AWD) vehicles and Two Wheel Drive vehicles do not have a Transfer Case (DTCM) and do not apply to the flash reprogramming of the
DTCM however still may require the flash programming of the TCM.**
MODELS:
2014 WK Grand Cherokee
NOTE: This bulletin applies to vehicles built on or before August 12, 2013 (MDH
0812XX) equipped with the 3.6L engine (Sales Code ERB) and the 845RE
Automatic Transmission (Sales Codes DFL).
SYMPTOM/CONDITION:
1. Harsh second gear to first gear/first gear to second gear shifts while using the paddle
shifter when the vehicle is not moving.
2. Upshift Improvements
a. Very low speed 1-2 upshift refined for smoothness
b. ECO mode 1-2 and 2-3 upshift refined for consistency of shift time & feel
c. Lift-foot (up to WOT) 1-2 and 2-3 upshift refined for smoothness
d. Sport mode 1-2 & 2-3 upshifts refined for energy conservation & feel
e. General cold-trip shift quality improvements
3. Downshifting Improvements
a. Coastdowns refined for smoothness (6-5, 5-4, 4-3, 3-2, 2-1)
b. All kickdowns refined for smoothness
c. All interlocked kickdowns refined for smoothness
d. General cold-trip shift quality improvements
4. Transfer Case Shift Improvements
JeepCares is online now
post #8 of 9 Old 12-12-2013, 10:26 PM Thread Starter
pt2005
2014 WK
@Lee: Thanks for the description of the TSB.
The dealer did the followings. I have no clues what the purposes of other TSB (18-041-13), PCM, and TCM are. If you can shred some lights on these, I'd appreciate it a lot. Thanks
TSB 18-041-13
PCM 68172002AI
TCM 68225629AB
pt2005 is offline
post #9 of 9 Old 12-13-2013, 07:42 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
PCM 68172002AI & TCM 68225629AB are part numbers.
BULLETIN NUMBER: 18-041-13
GROUP: Vehicle Performance
DATE: September 13, 2013
This bulletin is supplied as technical information only and is not an authorization for repair.
SUBJECT:
Flash: MIL Illumination P0606- Internal Control Processor
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM) with new software.
MODELS:
2014 (WK) Grand Cherokee
NOTE: This bulletin applies to vehicles equipped with a 5.7L engine (sales code
EZH), 3.6L engine (sales code ERB) or a 3.0L engine (sales code EHD) built
on or before August 26, 2013 (MDH 0826XX).
SYMPTOM/CONDITION:
A small number of customers may experience a Malfunction Indicator Lamp (MIL)
illumination. Upon further investigation the Technician may find that the following
Diagnostic Trouble Code has been set:
P0606 - Internal Control Processor
