Question about 6-speed transmission Wk2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Question about 6-speed transmission Wk2
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!
Unread 07-23-2015, 08:01 AM   #1
scross1220
scross1220's Avatar
2012 WK
Quick question to all 2011 WK2 owners, Has anybody heard of or knows of anyone that has been able to swap out the 5-speed transmission and put in a 6-speed transmission in a 2011 Jeep Grand Cherokee Laredo-X? Is it even possible to do so?
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[o]llllll[o]
_.(o)_)__(o)_)--o-)_)
If you're not fixing it, you're not driving a Jeep.
scross1220 is offline   Reply With Quote Quick reply to this message
Unread 07-23-2015, 09:25 AM   #2
jim_in_PA
2012 WK
It's the same transmission...AFAIK, the "5-speed" vs "6-speed" is more of a marketing designation for MY12-13 as there is one gear ratios different going up vs going down. At least for the Hemi. But I could be mistaken on that.
2012 Grand Cherokee Overland Summit 5.7L V8 - Winter Chill with New Saddle Interior - Nitto NT421Q
jim_in_PA is offline   Reply With Quote Quick reply to this message
Unread 07-23-2015, 01:30 PM   #3
loveracing1988
If you are talking about the V8 the transmission is identical, it is just a software change that I believe the dealer will do to 2011's. If it is a V6 no, there is no swapping it out, you dont really want to swap anyway as the Nag is a lot stronger of a transmission than the 65rfe/545rfe.
loveracing1988 is offline   Reply With Quote Quick reply to this message
Unread 07-23-2015, 01:52 PM   #4
nowakoaj
2011 WK
Can anyone verify that a 2011 V8 transmission can be upgraded via software to a 6 speed?
ajn
nowakoaj is offline   Reply With Quote Quick reply to this message
Unread 07-23-2015, 01:57 PM   #5
loveracing1988
ajn
The only difference is you can select all 6 gears. It doesn't make it a 6 speed like a normal 6 speed would be. In normal driving it will still only shift 5 times.
Unread 07-23-2015, 02:04 PM   #6
scross1220
scross1220's Avatar
2012 WK
Thanks for the info. I toasted the tranny at 45,640 mile and I am trying to hash it out with the dealership under warranty so I am looking at my options. Why is the 2012 different from the 2011? oh yes I have a 3.6L
______ooooo
/__l_l_,\____\,___
Unread 07-23-2015, 02:06 PM   #7
scross1220
scross1220's Avatar
2012 WK
I didn't know that. Thanks
______ooooo
/__l_l_,\____\,___
Unread 07-23-2015, 02:56 PM   #8
wyat72
2011 WK
The 5 speed in the v6 is the w5a580.
The "6 speed" you are inquiring about is the 65rfe, also called the 545re in its earlier software versions. The only difference between the two is a software update. I believe the 65rfe also has a more efficient torque converter. It was only behind the hemi for the wk2.
While the 65rfe is a solid transmission it has poor ratios and has a lot of internal losses which rob performance. I believe the 65rfe is incompatible with the v6, and if you were able to get it to work behind the v6, I believe it would make the v6 so sluggish it would be almost unbearable to drive. Plus because the ratios of the 65rfe and w5a580 are so different, you would also need to change axel ratios adding even more expense.
I would get another w5a580 and make sure to keep it serviced.
2011 Grand Cherokee Laredo X, Pentastar, Qudra Trac I.
wyat72 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2015, 05:56 AM   #9
scross1220
scross1220's Avatar
2012 WK
Good point. I will stick with the existing trans I have then. Still batting with Jeep as to the warranty issue but dealer said the would put a remanufactured one in for $700 what do you think?
______ooooo
/__l_l_,\____\,___
