Quadra Lift shocks replacement/repair - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Quadra Lift shocks replacement/repair
The Cure for your Tie Rod Roll!Offset Tie Rod Kit From RuffStuff!SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 04-21-2015, 08:24 PM   #1
jsbach
2012 WK
Has anyone ever had experience having had to replace (via the dealer) quadra lift air shocks due to either normal and tear over time or failure? Was the dealer able to complete the replacement successfully? Any issues? With a normal based spring suspension you figure it is a relatively straightforward maintenance issue/repair but with the QL is it different?
Just trying to anticipate when the time eventually comes when I'll need to have them replaced.
Grateful for any insights into your experience with this you can share.
jsbach is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 10:19 PM   #2
HVACNY
HVACNY's Avatar
2013 WK
My PO had the rear shocks replaced under warranty at about 20,000 miles.I thought that was strange and maybe a little early,but with this QL system it doesnt shock me.(no pun intended)
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 11:14 PM   #3
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
As far as replacing the air springs, its about the same effort as steel springs, if not easier as you can deflate them. There are a few air hoses to hook up that, if not done right, can leak. And then there is the nitrogen refill. The front shocks are integral with the air spring, the rear shocks are more conventional and can be replaced separately. The big difference is parts cost, where steel springs are less than $100, air springs are more than $1000 each.
These air springs are made by continental which has a good reputation for building durable springs.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 04-22-2015, 09:17 PM   #4
jsbach
2012 WK
Many thanks guys.
