QTII vs QDII - JeepForum.com
post #1 of 9 Old 12-11-2010, 07:26 PM Thread Starter
jeepsterguy
2011 WK
QTII vs QDII
The only difference I see between the two systems is the rear LSD.
Considering that JEEP believes that we don't need a front LSD due to braking action that will stop a spinning front wheel, why do we need a rear LSD (clutch type I was told, that will eventually wear out the clutches)? A lot easier to replace brake pads/rotors.
Just wondering.
jeepsterguy is offline
post #2 of 9 Old 12-11-2010, 08:18 PM
Nick_Knipp
1986 MJ Comanche
"Don't curse in your profile"
-The Moderators
'86 MJ XLS 4x4 2.8L 3spd longbed buckets
'12 MK Sport 2.4L AT rescue green
Nick_Knipp is offline
post #3 of 9 Old 12-12-2010, 02:22 AM
Marcus86GLHS
well if you are doing serious rock crawling and deep mud adventures every litle bit of extra traction is going to be needed, hence, locking differentials are beneficial. on snow and ice? not so much, but still a good thing to have. it is puzzling to me why the 2011 doesnt have a locking front diff, i bet it will in coming years.
2008 Hemi Grand Cherokee Limited 4 x 4, original owner, 29,000 miles
Marcus86GLHS is offline
post #4 of 9 Old 12-12-2010, 08:27 AM Thread Starter
jeepsterguy
2011 WK
http://www.youtube.com/watch?v=nIapRCQobKA&NR=1
In this video it looks like the brakes do a pretty good job.
post #5 of 9 Old 12-13-2010, 06:20 AM
Burb_Rated
2011 WK
The difference is between simply slowing a wheel that is spinning (the braking action of the traction control system) and transferring the torque of the wheel that is spinning to the lateral wheel that is not spinning. Forward energy is lost with the braking, while it is transferred to other wheels with traction with the LSD.
As for the implications of this, it depends on the situation. As the poster above said, it may not be very useful under certain circumstances--snow and ice perhaps. But, an important thing to remember is that the LSD does not hinder the traction control system that works with brakes. That system is still free to operate, which means that if you are in a situation where the torque transfer to the lateral wheel with traction (by the LSD) actually causes it to slip, then you still have the braking action of the TCS/ESC. The LSD is not a substitute, but an additional feature.
As I've mentioned before, the LSD is not exclusively and off-road feature. Sports cars, for example, rarely come without them. Torque transfer to an outer wheel in a curve, if needed, provides stability while maintaining forward momentum to a degree not possible with the simple braking action of a stability assist system.
As for potential issues with the clutch in the LSD, obviously, the more you use it, the more wear it will get. But, my sense is that LSD technology is well-established and longevity is not the problem that it might be with other "added features." A completely new ELSD may have some electronic issues to be sorted out, but hopefully that could be done with software updates, which aren't invasive.
I'll say it again, even the base QTI should have LSDs. They are a safety feature, and they enhance handling, even if you never go off-road.
BR
2011 GC Limited 4x4; Blackberry Pearl w/ Light Frost Beige; 5.7L HEMI; 20" Wheels; Tow Group IV; 730N
Burb_Rated is offline
post #6 of 9 Old 12-13-2010, 11:47 AM
Texas WJ
Texas WJ's Avatar
2005 WK
Take care of the ELSD and it will take care of you for a long time. I'm nearing 100,000 miles on mine and they're still working well.
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
post #7 of 9 Old 12-13-2010, 01:48 PM
AJeepZJ
2006 WK
Wk
That's actually a pretty good vid,it visually explains everything for those who don't see how it works.
All Gear, No Skill.
AJeepZJ is offline
post #8 of 9 Old 12-13-2010, 08:55 PM
Sarge_
BR
A front LSD is great on the trail, but an exception arrises on dirt 'softroads', or on pavement. With enough HP, a front LSD can introduce 'push' as the front outside wheel tries to accelerate and steer. I have a highly modified allroad (500 hp 87 octane, 800 hp on race gas). It has a custom rear-biased torsen center and LSD rear, and I opted against putting an LSD in the front because I wanted to have power oversteer when cornering. If the front had an LSD, it would tend to push and understeer.
Lighter cars like the WRX STi work OK with LSD's in front, but in heavier cars with softer suspensions, LSD's can wash out the grip on the outside front tire when cornering and accelerating.
In other words, I would think Jeep would offer a front LSD in the Overland, but not in the SRT8 version. For serious offroading, LSDs are far superior to brake systems.
All that said, some pretty crazy adventures have been had with no LSDs front or rear... (If you aren't compelled to read this entire story in one sitting, you probably don't need a Jeep anyway)
'06 Unlimited Rubicon, Midnight Blue, 6M
Previous Jeeps
'00 TJ Sport 4.0
'00 GC Laredo 4x4 V8
'95 YJ 2.5L
Sarge_ is offline
post #9 of 9 Old 12-13-2010, 09:58 PM Thread Starter
jeepsterguy
2011 WK
I have a Cherokee with front and rear Truetrac LSDs, I like them.
